Activity › Forums › Adobe After Effects › After Effect Trim Path is not Working as expected,,
  • After Effect Trim Path is not Working as expected,,
    Posted by Mohamed Imran on July 9, 2024 at 5:10 pm
    When using Trim Path, if I set the path end value to 50%, adjust the roundness, and change the shape size, I encounter a bug. Does anyone know what might be causing this or how to fix it?
    I Upload the bug screenshot below ;
    Hector Vera replied 2 years, 2 months ago 2 Members · 1 Reply
  • Hector Vera
    July 9, 2024 at 8:48 pm
    Would like to know exactly where its giving you that bug when you made the shape size. If the bug came from the size of the image, what is it that you wish to accomplish compared to whats going on here? I can see the image of a half circle but seems like you are trying to make a full circle perhaps? Not sure but more context on the issue and how you wish to fix it can be quite helpful.
