After effect suncing problem.
Hi!
You all know when you want to sync a clip to a music you will mark the beats and then mark the shots in the video and then drag the shots marks to the music beats marks.
I used to do the same thing but i used twixtor instead of time remapping. I stopped using the after effect for 1 year and today i wanted to edit the clip, but this method is not working. when i drag the shots speed marks in the twixtor to the beats marks it will not move the shot to the beat, it will change the speed of the part that is under the beat mark.
can somebody help?
i hop you understand what i’m trying to say xd.
this is how it used to look like : https://www.youtube.com/watch?v=RPysqaeJpK8&ab_channel=GhazalYazji
i used to mark the shots with twixtor and just drag the marks to the beats and the shot will be on the beat. idont remember how i used to do it :/ ??Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
