Activity › Forums › Adobe After Effects › after effect running slow after one hour of use but running fast again as soon as restarted?
Posted by Jean Mathis on December 6, 2011 at 4:22 pmAfter effect running slow after one hour of use but running fast again as soon as restarted? What could that be? Here are the specs of my machine:
Macbook pro unibody dual core april 2009, 2.53 GHZ, 8GB RAM
After effects CS5 (version 10.00)
Multiprocessing is disabled.
Open GL is abled (Adaptive res+Accelerate effects checked)
Disk cache enabled 4MBNothing improves when I purge all in edit menu.
All I can say when restart is: Well this works really nice!
Then after I while my enthusiasm gets totally spoiled.
Any advice would be greatly appreciated.
JeanJean Mathis replied 14 years, 9 months ago 3 Members · 11 Replies -
Kevin Camp
December 6, 2011 at 4:29 pmtry leaving about half your ram for ‘other apps’ in the memory settings.
i have a feeling that ae is starving your os of ram, causing it to disk cache. purge all would only clear the ae caches, not the system caches, so that may be the problem… though, restarting ae, might clear the os caches…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Kevin Camp
December 6, 2011 at 4:37 pmgood catch… i’d try dave’s suggestion first.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Jean Mathis
December 6, 2011 at 4:40 pmKevin this is an answer that goes against all the prejudices one can have about AE. We all try to upgrade the memory, the speed of our disks and processors constantly and then one guy comes with that strange idea ” give less memory” to AE, more to the system. Well, I will try it and let you know by tomorrow.
Thanks for your fast answer.
Jean -
Jean Mathis
December 6, 2011 at 4:52 pmWell Dave, if you would have read thoroughly my post you would have noticed that multiprocessing is turned off. This being said with all respect due to one of the most respectable, venerable, senior “Guru” sharing his merits here on CC (It means I really dig you Dude). But yes the treshold for multiprocessing is 16GB on a quadcore I7, I experienced this. I agree with this. So too much memory is sometimes not enough memory if the processor is not up to date. It echoes with kevin’s statement somehow. ; )
Walter Soyka
December 6, 2011 at 4:58 pmEven if it doesn’t fix your performance issue, you’ll thank yourself for updating as soon as you try to use AIFF audio…
Make sure your plugins are up-to-date, too, when you upgrade from 10.0 to 10.0.2. There were some problems with earlier releases of Colorista II and Particular [link].
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Jean Mathis
December 6, 2011 at 5:04 pmYes I know Dave, AE CS5 10.0 has some serious bugs (called “issues” at Adobe), I have 5.5 already installed but Its just a drag to reinstall al the plugs. Thanks for the advice, you are right I should do it ASAP.
Jean Mathis
December 6, 2011 at 5:09 pmYes I know about he AIFF audio “bug”, It took me a while to understand this problem BTW, I used .waw sound after this, I was editing a rap video clip, it was such a drag till I understood.
I have CS5.5 installed already, Its just a drag to reinstall all the plugs. -
Jean Mathis
December 6, 2011 at 5:20 pmThis is great news Dave! I will check it out ASAP. A million Thanks!
Jean -
Jean Mathis
December 7, 2011 at 5:23 amActually I searched the forum but could not find anything relating to this topic. Is it possible to ask Rick Gerard directly?
Jean Mathis
December 7, 2011 at 5:26 amDave suggested me to disable multiprocessing but if you read the original post I mentioned in it that this was disabled already. I tried your solution but nothing changed. At some point my memory is starving out gradually. I will upgrade to 5.5 maybe that will fix was obviously is a memory management issue.
