Activity Forums Adobe After Effects After effect PC
  • After effect PC
    Posted by Aisha Jafar on April 30, 2008 at 10:23 am
    how can i set up my PC to be much helpful with after effect CS3
    how much RAM,Hard disk i need?
    what Grafic Card i need?
    i have pinnacle RT is doest it work?
    what is much better Declink or Matrex RT?
    i need render to be much faster
    and also Real time output
    Jeremy Fabiano replied 18 years, 3 months ago 3 Members · 5 Replies
  • Richard Harrington
    May 3, 2008 at 2:38 am
    [Aisha Jafar] “how can i set up my PC to be much helpful with after effect CS3
    and also Real time output”
    Helpful… well read the tip of the day at startup and the Online Help menu
    Graphics card… 256+ of dedocated VRAM
    Matrox and Decklink matter not to AE since you can’t capture with that App
    Render Faster… thats processor and RAM
    Real Time Outpiut.. to what?
    your post needs some claritu to say the least.
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Jeremy Fabiano
    May 16, 2008 at 3:01 pm
    Will try to help, even though more information is required to have a good answer…
    Well, you want at LEAST 1 gigabyte per cpu core, as for hard disk… video files can get quite large.. so the more HD you have, the less headaches you’ll get later (I would suggest something with the SATA interface, if you can afford it maybe some SCSI HD’s @10,000 RPM for faster access… but minimum 7200 RPM no less (5400 is cheap, but SLOOOOOW)
    something that works decent. I like the nVidia 8600 GTS/OC – fairly priced for the features, and it supports overclocking from the factory – dont do this without good cooling..
    Sry no clue
    Sry no clue
    cpu with multiple cores (or multiple cpu’s with multiple cores)
    also have heard good things about “Gridiron Nucleo/pro”
    on a budget? find a bunch of old pc’s and learn about render farms..
    to what?
    sorry I can’t be of more help, but the post is lacking in general information..
    Hope I was of some help.
    -Jeremy
  • Aisha Jafar
    May 17, 2008 at 7:51 am
    Thank you
    sry i mix two question in one
    about Premiere:
    i have adobe premiere 6.5(i already have pinacle RT)
    but i want to install adobe premiere pro so pinacle RT is good for it?or i should change the card?
    about After effect :
    i change the HD to 300 GB,RAM to 5 GB grafic card NVIDIA
    but my PC only read 2 GB of RAM and i dont know why
    Thx
  • Jeremy Fabiano
    May 18, 2008 at 4:41 am
    I can’t help with Premier as I haven’t used it.
    Your HD should be fine, although if you’re doing production work, you really should have multiple drives (including one dedicated for AE’s cache thing) and one dedicated for your project files and one for your OS .. if you start running out of room (under 5-10gb) windows will start to go really slow etc and slow down your workflow..
    As for your memory, you need a 64bit operating system.
    Standard 32bit OS’s only seem to detect 2-3 GB from what I’ve read.
    If you do upgrade your OS make sure you have a 64bit CPU (which you already might since you can support more memory than 32bit boards do if i recall correctly..)
    Hope this helps 🙂
    -Jeremy
  • Jeremy Fabiano
    May 18, 2008 at 4:45 pm
    Sry I was tired last night.
    32bit os detects only 4 gigs of ram.
    64bit will detect more
