Activity Forums Adobe After Effects After Effect error: Particular cannot work on a time-reversed layer
  • After Effect error: Particular cannot work on a time-reversed layer
    Posted by Bruna Pastore on September 20, 2015 at 9:31 pm
    I’m using trapcode particular on my After Effects CC 2015, but when I applied Time-reversed Layer, I received this message. “After Effect error: Particular cannot work on a time-reversed layer”
    I tried pre-compose. I also tried render, but nothing are working. If someone can help me it would be great!
    Beata Nowak replied 8 years, 11 months ago 5 Members · 5 Replies
  • Bruna Pastore
    September 21, 2015 at 4:02 pm
    Hi, thanks for answer me back.
    I also tried in After Effect CS4 and CS6.
    Both of them keep the same error.
    I’ve tried a lot, I have no ideia what’s happening.
    Is there another way to do that?
    I’m learning AE.
  • Kalleheikki Kannisto
    September 21, 2015 at 5:01 pm
    I take that to mean that Particular doesn’t work on a time-reversed layer for a reason. The likely reason being that Particular has a built-in Physics Time Factor that you can use to speed up or slow or reverse time.
  • Rosa Hughes
    May 19, 2016 at 4:47 am
    I still get the error message when I precompose Particular and do time-remapping (using the latest version of CC).
    I found the only way to get it to work is to go into the advanced comp settings (of your Particular comp) and check the ‘preserve frame rate when nested’ box.
  • Brandon Irwin
    May 27, 2016 at 5:37 pm
    Life saver! thank you so much. Clicking that box in advanced COMP settings allows particular to be time reversed!!! Thanks
  • Beata Nowak
    October 12, 2017 at 11:45 pm
    Dear Dave,
    I have stumbled upon this issue today and figured out a different solution.
    If you time-reverse the comp with trapcode particular applied to it and precompose the whole thing, it will work on time-reversed layer in the main comp, but not in the precomp. Double reversal does the tricks. Just another way to go around it.
    Regards,
    Bet
