Activity Forums Adobe After Effects After Effect Crash due to Boris Continuum when i open mmy project its crashed
  • After Effect Crash due to Boris Continuum when i open mmy project its crashed
    Posted by Damanpreet Singh on October 7, 2024 at 10:47 pm
    Hey everyone,
    I’ve been having an issue with After Effects where my project files keep crashing whenever I try to open them, but this only happens if I have the Boris Continuum plugin installed. I’m currently using Boris Continuum 2024.5 with After Effects 2019. As soon as I try to load a project that uses the plugin, After Effects crashes instantly.
    I’ve already tried reinstalling both After Effects and Boris Continuum, but no luck so far. Has anyone else experienced something similar or have any ideas on how to fix this? Any help would be really appreciated! Thanks!
    Walter Soyka replied 1 year, 10 months ago 2 Members · 1 Reply
  • Walter Soyka
    October 9, 2024 at 6:39 pm
    You might try holding down the Shift key while opening your project. This will open the project without opening (and therefore attempting to render) any comps in timeline or viewer panels.
    From there, you can open comps with Caps Lock engaged to prevent the viewer from rendering.
    Maybe then, you can narrow down which comp and which specific layer is causing the crash, then try removing or modifying the effect to see if you can work around the crash, or get more information that you can share with BorisFX support.
