Activity Forums Media 100 after batch digitizing the player works slow
  • after batch digitizing the player works slow
    Posted by Macmauro on April 27, 2006 at 7:32 pm
    hi, i used my digital player for batch digitizing in m100
    via firewire (i know i have to use it via RS422 connector )
    the problem now is that when i control the deck from m100
    to forward or backward the tape while the play button is on
    the deck doesn’t run fast as it did before
    but move the images slowly, frame by frame,
    also using the keyboard
    why? What can i do to reverse this function?
    thanks
    Maurizio
    Kieran Matthew replied 20 years, 5 months ago 2 Members · 1 Reply
  • Kieran Matthew
    April 27, 2006 at 9:44 pm
    I’m guessing here, but it sounds like you’ve got it in “jog” mode rather than “shuttle”. You can toggle between them with that oval button with the two arrows to the left of the transport buttons on the Digitise pane.
    Hope that helps
