Activity Forums VEGAS Pro After applying effects how to create a new folder of individual clips in avi?
  • After applying effects how to create a new folder of individual clips in avi?
    Posted by Michael33 on June 14, 2007 at 1:50 pm
    I would appreciate your help.
    I just finished adding effects (color correcting, brightness, etc.)
    to each of the clips (.avi files in a folder on my hard drive) on the time line.
    Then I want to make a complete new – updated copy of each and every clip of the .avi files in a separate hard drive folder after I applied the above effects.
    How can I do this the most fast and efficient way without creating a subclip or doing them one at a time for each clip?
    Thanks.
    Gary Kleiner replied 19 years, 2 months ago 2 Members · 1 Reply
  • Gary Kleiner
    June 14, 2007 at 4:19 pm
    No real fast way. You’d have to render each one out. You can do this with batch render to be more effecient (and unnatended). I would suggest lining them up sequentially, making each clip a seperate region and batch render the regions to whatever folder you want.
    Just as a ponint of information, you can apply your FX to the separate files on a project level, then they will have their FX automatically wherever you use them in the project. However, rendering them as you suggest will probably imrove your playback frame rate.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
