Activity › Forums › Adobe After Effects › After Affects error
After Affects error
Posted by Sarah_casson_designer on May 30, 2007 at 4:15 pmAfter Affects error: OpenGL: Failed to release dc.
Can anyone tell me what this means…? And how I can go about fixing it?
My graphics card is nvida gforce 7 seris.
Thanks in advance.
Kind regards
sarah
Sarah_casson_designer replied 19 years, 4 months ago 2 Members · 6 Replies -
Kevin Camp
May 30, 2007 at 4:28 pmthe easy way is to get into your preview preference and turn off opengl
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
May 30, 2007 at 4:51 pmFantastic – thanks!
This wont affect anything will it…? like the final output etc…? Do i turn it back on after ive finished what Im doing…?
If i turn it off will it stop me from previewing effects etc…?
Thanks in advance!
Kevin Camp
May 30, 2007 at 4:58 pmsorry for the brief answer, i was getting interupted (work… i tell ya). many people just disable opengl previews from the get go, because it can get kind of flakey in ae. also it really wasn’t much good until ae7 and even now it’s limited.
you can also switch the preview render technology with the little button that has the lightning bolt at the bottom of the preview window.
Kevin Camp
Kevin Camp
May 30, 2007 at 5:01 pmin response to your other question… no it won’t effect a thing, unless you happend to set your final render settings to specifically use opengl to render (it seems even adobe realized opengl was flakey when they implemented it, by default your final render settings use the statndard software render engine).
Kevin Camp
May 30, 2007 at 5:08 pmThanks ever so much Kevin – youre a little star! Great help!
Dont work too hard now. Bless.
xXx
