Activity › Forums › DaVinci Resolve › Affordable Reference Monitor for color grading
Posted by Marcelo Tché franco on September 18, 2015 at 6:05 pmHello there,
I’m trying to find a good Reference Monitor that is affordable for me (maximum of $2,000).
I have a DeckLink SDI card, so I’m thinking of a SDI Monitor.
I am going to use this monitor for color grading, and it don’t need to be a big screen, 17” seems ok to me.Any sugestions?
Marcelo Tché franco replied 11 years ago 4 Members · 7 Replies -
Bill Ravens
September 19, 2015 at 12:13 pm“Affordable” is a relative term. Your best bet is to go with a monitor that has an ability to internally store a user generated LUT. Then, calibrate it with a tool like s p e c t r a c a l.NEC makes some nice models that do this with IPS displays. Short of this approach, it might make a lot of sense to buy a LUT box, like the Fuji IS-Mini, that you can plug in to any display. The only real requirement is to get a display that has an expanded colorspace, like the ones that have 99% Adobe RGB.
Marcelo Tché franco
September 19, 2015 at 7:05 pmSo, you think somethink like ‘ Dell U2415 24″ Widescreen LED Backlit IPS Monitor ‘ Calibrated with a LUT box might be what I need?
Then my ‘decklink sdi 4k’ card will be of no use for now?
Many thanks!
Marcelo Tché franco
September 21, 2015 at 11:11 amI would sure like to have a Flanders Scientific, but I can’t afford it yet (and I’m from Brazil, so It is a little bit complicated to find FSI Monitors, only importing, and the TAX are insane.)
For now I’m trying to find something so I can start working as colorist.
Thanks! -
David Chai
September 25, 2015 at 2:45 amI haven’t used it or seen one, but if price is a concern and you need SDI, B&H sell something called the View Z VZ-215LED-SN for around $755 US. From what I’ve gathered around the internet, they are a South Korean company that make OEM displays for broadcast and other industries. Now they launched their own label, so the quality should be decent. But I can’t vouch for them since I haven’t used one, but B&H typically don’t stock things if they are not somewhat reputable.
David Chai – Writer . Director
http://www.davidchai.com -
Marcelo Tché franco
September 25, 2015 at 2:20 pmThank you guys!
Unfortunately here in Brazil everything is too expensive, and now 1 Dolar is 4 Reais.I’ll try to find something good here, and maybe in a few years get money enough to buy something better!
Thanks again!
