Activity › Forums › Apple Final Cut Pro Legacy › Affordable Monitors
  • Affordable Monitors
    Posted by Maria on May 10, 2006 at 1:40 pm
    I have a little budget to buy a monitor and I’m tempted by the economically priced
    JVC TMH-150CGU 15-Inch Color Production Monitor with 750 Lines, 16:9 and 4:3 Aspect Switch, NTSC and PAL Systems
    which is about $500.000 at B&H – Sonys seem to start over $1,000 and that’s a little out of range for me. But am I limiting myself too much getting the JVC? I shoot 24PA on the DVX 100B and edit in FCP HD.
    Many thanks for any input.
    Maria replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 10, 2006 at 3:00 pm
    What you’d not get is the SMPTE phosphors that the Sony monitors have— that’s the biggie… they are more color accurate. But the JVC is a TON better than a TV because you can set it up properly with bars, and is likely close enough.
    Jerry
  • Maria
    May 10, 2006 at 3:03 pm
    Thank you Jerry – that’s what I gathered, but I figured where I’m not doing work that requires very faithful similarity to other monitors or to strict broadcast standards, I might get away without them. I appreciate the advice.
