Activity › Forums › Adobe After Effects › AF crash problem
AF crash problem
Posted by Leo Manya on April 13, 2007 at 6:45 pmHI,
After Effects crashes when loading, just whet it says “loading user interface”. No error message, just crashes…
any known issues?
I uninstalled/installed, repaired.. with no success.
I’m running: AF 7.0 on XP pro. 32b.thanks.
Leo Manya replied 19 years, 4 months ago 3 Members · 6 Replies -
Leo Manya
April 13, 2007 at 6:47 pmSorry for double posting. I hope I’m posting at the right section.
Thanks again. -
Nicholas Toth
April 13, 2007 at 8:40 pmAHHHHH!
The same thing happened on my Macbook Slow — I wound up having to actually wipe the windows end, then re-install. It kind of happens out of nowhere.
Does your screen turn blue? If you get the blue screen make sure all of your drivers are up to date — I’ve had that happen frequently also —-
Lastly, if it comes down to it, try a windows repair install.
Jan Sherlink
April 14, 2007 at 7:09 amHad this on my Laptop,
move the Open-GL Plug-In out of your AE-Plug-In folder.
Try to start AE now.
If it starts you might want to check the latest driver for your videocard.
But nothing garantees it’s an Opel-GL problem 🙁 -
Leo Manya
April 14, 2007 at 3:11 pmThanks a lot for your help.
It’s not a openGl problem 🙁 ..
I did a new install (formated HD, windows new install) then installled AE , It worked fine the fisrt 2 times and then again it started to crash at startup.. I’ve no idea of what’s going on.
thanks again.
Jan Sherlink
April 14, 2007 at 4:19 pmHave you installed a lot of extra Plug-In’s ?
Could be that AE is hanging on one of them.
If you temporary move extra installed Plug-In’s to another folder on your hard disk, and AE starts up …..trashing your AE preferences is another option,
start AE while holding Control-Alt-Shift -
Leo Manya
April 14, 2007 at 11:11 pmFinally it works 🙂
… I have no idea why, I did everything I could think of (even some voodoo dancing) in the end I have no idea what was problem.Thanks for the alt+shift tip, I’m sure it will come in handy 😉
Thanks.
