Activity Forums Adobe Premiere Pro ?Project settings for DVCProHD 720p 24fps…What to do, what to do
  • ?Project settings for DVCProHD 720p 24fps…What to do, what to do
    Posted by Jake Hawkes on October 9, 2007 at 10:02 pm
    I am so happy, hurrah Adobe picked up MXF file support…so I open up premier and begin…hmmm, hurrumph…
    What should I do? I could select a HDV project setting or set up custom. If I select custom do I want to set the aspect as 720 x 1280…my HVX200 doesn’t capture in 720 x 1280, but rather a slightly off size that has me wondering.
    I went ahead and used a default HDV setting and everything appears to look correct…but I have been here before, only to find out later that the frame rate/aspect or fields was way off after rendering: Titles, video, transitions, ETC.
    Any sugestions?
    Vince Becquiot replied 18 years, 11 months ago 2 Members · 1 Reply
  • Vince Becquiot
    October 9, 2007 at 11:13 pm
    A far as I know the support patch is yet to be out.
    It will however be out this month. Until then you can either use Cineform/Raylight, or Capture with OnLocation.
    DVC Pro HD uses an anamorphic ratio.
    Vince
