Activity Forums Adobe After Effects AE/Premiere-interchange _ filetype issue
  • AE/Premiere-interchange _ filetype issue
    Posted by Gunnar Kordestani on June 6, 2007 at 2:25 pm
    hello everybody,
    as I am used to QUANTEL EDITBOX I never got in touch with theese kind of issues and so I am more or less clueless….
    I have HDV 1080i, 1440×1080 footage
    edit with Premiere, than post with AE
    The result shouold be a PAL 4:3 with Letterbox
    1) Premiere tu AE i chose:
    filetype: Quicktime
    Compressor: Planar RGB
    720×576 16:9
    25 fps
    Pix Aspect Ratio: D1/DV PAL Widescreen (1.422)
    upper field first
    I imported into AE and made a composition out of my .mov.
    was a PAL 720×576. I had to shange the size of my .mov to 100×75 to get rid of the distortion.
    the Final Render was in ‘mpeg, no Audio’
    Later of course i discovered the possibu
    Gunnar Kordestani replied 19 years, 3 months ago 15,513 Members · 1 Reply
  • Gunnar Kordestani
    June 6, 2007 at 11:24 pm
    nobody has any comment? come on guys, you know it don’t you?
