Activity Forums Adobe After Effects AEP file makes AE CS6 crash. No import possible
  • AEP file makes AE CS6 crash. No import possible
    Posted by Paul Emous on December 12, 2013 at 11:36 am
    Okay. I am about to become suicidal here.
    I am running healthy spec-ed i7 iMac OSX 10.8.5 with CS6 (full specs below in the crash log)
    I was working on this Premiere project with AE comps in it. Nothing heavy of complex. Just some kinetic typography made with TypeMonkey and some low res images.
    After numerous saves (both Pr and AE) I decided to render the final result. And for some reason the render got stuck (Pr). So I decided to reboot my machine and start again.
    Now I can’t open the AEP file it crashes after trying to load comp 6. Also my Premier file is F*cked because 95% of it is that darn AEP file and its giving me the spinning ball of death.
    I tried to import into a black project -> Crash.
    I tried to import the AEP file without the media linked. -> Crash
    I tried to use a different Mac with CS6 -> Crash
    I uninstalled all the expensive Red Giant and Saphire plug-ins (which this project doesn’t use-> Crash.
    I tried to use a windows 7 machine with AE CC -> Crash.
    I read that it is possible to open the file in a text editor but so far this hasn’t been successful. Although all comps are pretty much similar I have a feeling comp 6 is corrupt. Is there a way to extract this comp via a hex or txt editor? After Effects seems impossible to deal with it.
    Suggestions are MOST welcome.
    Crash log:
    Process: After Effects [991]
    Path: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
    Identifier: com.adobe.AfterEffects
    Version: 11.0.2 (11.0)
    Code Type: X86-64 (Native)
    Parent Process: launchd [281]
    User ID: 501
    Date/Time: 2013-12-12 15:21:44.276 +0400
    OS Version: Mac OS X 10.8.5 (12F45)
    Report Version: 10
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000001b7
    VM Regions Near 0x1b7:
    __TEXT 0000000100000000-0000000100004000 [ 16K] r-x/rwx SM=COW /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 BEE.dylib 0x000000010110c390 BEE_GetEffectParamIndexFromPath(BEE_Layer const*, TDB_StreamIDPath const&) + 640
    1 TDB.dylib 0x00000001020b911b TDB_ParamLayerStream::GetFlattenedReserved0() const + 61
    2 TDB.dylib 0x00000001020aca4c TDB_Stream::Write(SLU_File*) const + 1738
    3 TDB.dylib 0x00000001020c090d TDB_StreamGroup::Write(SLU_File*) const + 927
    4 FLT.dylib 0x000000010176017e FLT_FCSeqSpec::Write(SLU_File*) const + 1656
    5 TDB.dylib 0x00000001020c090d TDB_StreamGroup::Write(SLU_File*) const + 927
    6 TDB.dylib 0x00000001020c090d TDB_StreamGroup::Write(SLU_File*) const + 927
    7 BEE.dylib 0x00000001010f2c9c BEE_Layer::WritePlus(SLU_File*, BEEp_FileInfo*) + 162
    8 BEE.dylib 0x00000001010f2b17 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string, dvacore::utility::SmallBlockAllocator::STLAllocator > const*, BEE_Project*) + 12309
    9 BEE.dylib 0x00000001010eb87e BEE_RegisterPresetLocalizationString(char const*, char const*) + 2574
    10 BEE.dylib 0x000000010104f904 BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 1044
    11 BEE.dylib 0x00000001010f4c64 BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set, std::allocator > const*, FILE_Spec*) + 4484
    12 com.adobe.AfterEffectsLib.framework 0x00000001007fab54 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 356
    13 com.adobe.AfterEffectsLib.framework 0x00000001007fb876 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 3718
    14 com.adobe.AfterEffectsLib.framework 0x00000001007fa182 CTopicArray::~CTopicArray() + 59154
    15 com.adobe.AfterEffectsLib.framework 0x0000000100492845 GetMetaPanelSuite + 9061
    16 com.adobe.AfterEffectsLib.framework 0x00000001004922f7 GetMetaPanelSuite + 7703
    17 U.dylib 0x0000000102b5ec11 U_Die + 241
    18 U.dylib 0x0000000102b7ef3d U_LoadFrameworkBundle + 557
    19 com.adobe.dvacore.framework 0x0000000102fd1535 (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 261
    20 libsystem_c.dylib 0x00000001095e690a _sigtramp + 26
    21 TXT.dylib 0x00000001023d126b SLO::ConstAutoResource::ConstAutoResource(SLO::ConstAutoResource const&) + 139
    22 TXT.dylib 0x00000001024c29e4 SLO::OldNormalCharStyleToParaStyleResolver::SourceAndDestNormalsAreTheSame(SLO::DocumentResources&) const + 324
    23 TXT.dylib 0x00000001024c2dea SLO::OldNormalCharStyleToParaStyleResolver::ResolveWithThis(SLO::DocumentResources&) + 26
    24 TXT.dylib 0x00000001024da4bf SLO::TextModel::TextModel(SLO::TextModel const&, SLO::Document&, SLO::AutoPtr const&, SLO::Array >) + 3631
    25 TXT.dylib 0x00000001024072f5 SLO::Document::CloneTextObjectWithIdenticalFrames(SLO::ConstAutoPtr const&, SLO::List > const&) + 389
    26 TXT.dylib 0x000000010240dc84 SLO::Document::CloneTextObject(SLO::ConstAutoPtr const&) + 1396
    27 TXT.dylib 0x000000010219d564 TXT_ShutdownGlobalDocumentResources() + 9610
    28 TXT.dylib 0x00000001021216d6 TXT_Doc::TXT_Doc(int, TXT_GlobalDoc const&, TXT_GlobalDoc&) + 158
    29 BEE.dylib 0x0000000101153b41 BEE_DefaultTextDocument::GetValue() + 10551
    30 BEE.dylib 0x000000010114bf1d BEE_TextDocumentStream::Read(SLU_File*, SLU_ChunkInfo const*) + 647
    31 TDB.dylib 0x00000001020c5992 TDB_NamedStreamGroup::ReadAndStore(TDB_MatchName const&, SLU_File*, SLU_ChunkInfo const*) + 240
    32 TDB.dylib 0x00000001020c051e TDB_StreamGroup::Read(SLU_File*, SLU_ChunkInfo const*) + 238
    33 TDB.dylib 0x00000001020c5992 TDB_NamedStreamGroup::ReadAndStore(TDB_MatchName const&, SLU_File*, SLU_ChunkInfo const*) + 240
    34 TDB.dylib 0x00000001020c051e TDB_StreamGroup::Read(SLU_File*, SLU_ChunkInfo const*) + 238
    35 BEE.dylib 0x00000001010efb79 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string, dvacore::utility::SmallBlockAllocator::STLAllocator > const*, BEE_Project*) + 119
    36 BEE.dylib 0x00000001010f2412 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string
    , dvacore::utility::SmallBlockAllocator::STLAllocator > const*, BEE_Project*) + 10512
    37 BEE.dylib 0x00000001010f2631 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string
    , dvacore::utility::SmallBlockAllocator::STLAllocator > const*, BEE_Project*) + 11055
    38 BEE.dylib 0x00000001010f10c2 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string
    , dvacore::utility::SmallBlockAllocator::STLAllocator > const*, BEE_Project*) + 5568
    39 BEE.dylib 0x00000001010f2733 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string
    , dvacore::utility::SmallBlockAllocator::STLAllocator > const*, BEE_Project*) + 11313
    40 BEE.dylib 0x00000001010f7529 BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set, std::allocator > const*, FILE_Spec*) + 14921
    41 BEE.dylib 0x00000001010f7f81 BEE_LoadProject(FILE_Spec*, BEE_FolderItem*, unsigned char, unsigned char, unsigned char*, BEE_ActiveItemInfo*, unsigned int*, BEE_Project*) + 193
    42 BEE.dylib 0x00000001010129eb BEE_TimeDisplayFormat2T_TimeFormatInfo(BEE_TimeDisplayFormat const*, T_TimeFormatInfo*) + 491
    43 BEE.dylib 0x00000001011a697e BEE_UndoRedoCount(int*, int*) + 110
    44 BEE.dylib 0x0000000101014b31 BEE_DoCommand(short, BEE_CommandInfo*) + 449
    45 com.adobe.AfterEffectsLib.framework 0x00000001007fbf7b CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 5515
    46 com.adobe.AfterEffectsLib.framework 0x000000010043048a CEggApp::OpenDocument(FILE_Spec**, unsigned char, unsigned char, unsigned char) + 404
    47 com.adobe.AfterEffectsLib.framework 0x00000001002da123 0x1002a7000 + 209187
    48 com.apple.AppKit 0x0000000109ef6777 __69-[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:]_block_invoke_0 + 1674
    49 com.apple.AppKit 0x0000000109ca8ec3 -[NSDocumentController(NSInternal) _autoreopenDocumentsWithCompletionHandler:] + 64
    50 com.apple.AppKit 0x0000000109ca766e -[NSApplication _reopenWindowsAsNecessaryIncludingRestorableState:registeringAsReady:completionHandler:] + 298
    51 com.apple.AppKit 0x0000000109ef6064 -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 306
    52 com.apple.AppKit 0x0000000109ca7034 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 327
    53 com.apple.Foundation 0x000000010b6a007b -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 308
    54 com.apple.Foundation 0x000000010b69fedd _NSAppleEventManagerGenericHandler + 106
    55 com.apple.AE 0x000000010dc6c078 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 307
    56 com.apple.AE 0x000000010dc6bed9 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 37
    57 com.apple.AE 0x000000010dc6bd99 aeProcessAppleEvent + 318
    58 com.apple.HIToolbox 0x000000010bc29709 AEProcessAppleEvent + 100
    59 com.apple.AppKit 0x0000000109ca3836 _DPSNextEvent + 1456
    60 com.apple.AppKit 0x0000000109ca2df2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
    61 com.apple.AppKit 0x0000000109c9a1a3 -[NSApplication run] + 517
    62 com.adobe.AfterEffectsLib.framework 0x00000001004c3955 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 128453
    63 com.adobe.AfterEffectsLib.framework 0x000000010046206b SetAPETerminateFunc(boost::function const&) + 891
    64 com.adobe.AfterEffectsLib.framework 0x000000010046282d EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 61
    65 com.adobe.AfterEffects 0x0000000100003aad main + 1677
    66 com.adobe.AfterEffects 0x000000010000340c start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0 libsystem_kernel.dylib 0x0000000109761d16 kevent + 10
    1 libdispatch.dylib 0x000000010957bdea _dispatch_mgr_invoke + 883
    2 libdispatch.dylib 0x000000010957b9ee _dispatch_mgr_thread + 54
    Thread 2:
    0 libsystem_kernel.dylib 0x00000001097616d6 __workq_kernreturn + 10
    1 libsystem_c.dylib 0x00000001095faf1c _pthread_workq_return + 25
    2 libsystem_c.dylib 0x00000001095face3 _pthread_wqthread + 412
    3 libsystem_c.dylib 0x00000001095e5191 start_wqthread + 13
    Thread 3:
    Thread 4:
    0 libsystem_kernel.dylib 0x00000001097610fa __psynch_cvwait + 10
    1 libsystem_c.dylib 0x00000001095fcfb9 _pthread_cond_wait + 869
    2 com.apple.CoreServices.CarbonCore 0x000000010d6d0210 TSWaitOnCondition + 108
    3 com.apple.CoreServices.CarbonCore 0x000000010d6d03e7 TSWaitOnConditionTimedRelative + 132
    4 com.apple.CoreServices.CarbonCore 0x000000010d632a98 MPWaitOnQueue + 252
    5 com.adobe.dvacore.framework 0x0000000102f4bce4 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr > >&, int) + 200
    6 com.adobe.dvacore.framework 0x0000000102f48fe3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 115
    7 com.adobe.dvacore.framework 0x0000000102f466d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 163
    8 com.adobe.boost_threads.framework 0x0000000110df6ace thread_proxy + 158
    9 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    10 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    5 com.adobe.ACE 0x0000000111d862c9 0x111d4d000 + 234185
    6 com.adobe.ACE 0x0000000111d855da 0x111d4d000 + 230874
    7 com.apple.CoreServices.CarbonCore 0x000000010d6a77e0 PrivateMPEntryPoint + 58
    8 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    9 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    5 com.adobe.ASLFoundation.framework 0x0000000105c09320 ASL::(anonymous namespace)::TaskProc(void*) + 160
    6 com.apple.CoreServices.CarbonCore 0x000000010d6a77e0 PrivateMPEntryPoint + 58
    7 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    8 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    1 com.adobe.dvatransport.framework 0x0000000108e29f12 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue&) + 240
    2 com.adobe.dvatransport.framework 0x0000000108e340da boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::idle_thread_info*) + 512
    3 com.adobe.dvatransport.framework 0x0000000108e34467 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 291
    4 com.adobe.dvatransport.framework 0x0000000108e20fbd SkyConnectionEnv::MainLoop() + 129
    5 com.adobe.dvatransport.framework 0x0000000108e2103b SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
    6 com.adobe.boost_threads.framework 0x0000000110df6ace thread_proxy + 158
    Thread 21:
    2 com.adobe.dvatransport.framework 0x0000000108e3404b boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::idle_thread_info*) + 369
    4 com.adobe.dvatransport.framework 0x0000000108e21c2a boost::asio::detail::posix_thread::func::run() + 42
    5 com.adobe.dvatransport.framework 0x0000000108e24c33 boost_asio_detail_posix_thread_function + 19
    6 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    7 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 22:
    0 libsystem_kernel.dylib 0x000000010975f686 mach_msg_trap + 10
    1 libsystem_kernel.dylib 0x000000010975ec42 mach_msg + 70
    2 ??? 0x0000000120fd8212 0 + 4848452114
    3 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    4 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 23:
    2 com.adobe.AfterEffects.MThread 0x000000012f9bb017 main + 27303
    3 com.adobe.AfterEffects.MThread 0x000000012f9bb0ce main + 27486
    4 com.adobe.dvacore.framework 0x0000000102f466d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 163
    5 com.adobe.boost_threads.framework 0x0000000110df6ace thread_proxy + 158
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    2 com.adobe.AfterEffects.OpenEXR 0x0000000132b3e484 IlmThread::Semaphore::wait() + 100
    3 com.adobe.AfterEffects.OpenEXR 0x0000000132b3d546 IlmThread::(anonymous namespace)::WorkerThread::run() + 182
    4 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    5 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 32:
    Thread 33:
    Thread 34:
    Thread 35:
    Thread 36:
    Thread 37:
    Thread 38:
    Thread 39:
    0 libsystem_kernel.dylib 0x0000000109761386 __semwait_signal + 10
    1 libsystem_c.dylib 0x00000001096827c8 nanosleep + 163
    2 com.adobe.AfterEffects.Scripting 0x0000000133d833eb zcalloc + 188043
    3 com.adobe.AfterEffects.Scripting 0x0000000133d6a069 zcalloc + 84745
    4 com.adobe.AfterEffects.Scripting 0x0000000133d83736 zcalloc + 188886
    5 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    6 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 40:
    2 com.adobe.ape.engine 0x00000001348b6c0d APXGetHostAPI + 2516093
    3 com.adobe.ape.engine 0x0000000134664ec1 APXGetHostAPI + 83761
    4 com.adobe.ape.engine 0x00000001348b6cd1 APXGetHostAPI + 2516289
    5 com.adobe.ape.engine 0x00000001348b6d4a APXGetHostAPI + 2516410
    6 com.adobe.ape.engine 0x00000001348b6e79 APXGetHostAPI + 2516713
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    2 com.apple.CoreFoundation 0x000000010921e233 __CFRunLoopServiceMachPort + 195
    3 com.apple.CoreFoundation 0x0000000109223916 __CFRunLoopRun + 1078
    4 com.apple.CoreFoundation 0x00000001092230e2 CFRunLoopRunSpecific + 290
    5 com.apple.CoreMediaIO 0x00000001374bc6e8 CMIO::DAL::RunLoop::OwnThread(void*) + 146
    6 com.apple.CoreMediaIO 0x00000001374b42ce CAPThread::Entry(CAPThread*) + 156
    Thread 45:
    1 libsystem_c.dylib 0x00000001095fcff3 _pthread_cond_wait + 927
    2 com.adobe.ape.engine 0x00000001348b6bd0 APXGetHostAPI + 2516032
    3 com.adobe.ape.engine 0x00000001348ceddb APXGetHostAPI + 2614859
    Thread 46:
    3 com.adobe.ape.engine 0x0000000134a492c3 APXGetHostAPI + 4164403
    Thread 47:
    2 libtbb.dylib 0x0000000100017010 tbb::internal::rml::private_worker::thread_routine(void*) + 416
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    2 com.adobe.AfterEffectsLib.framework 0x000000010040c6f7 ae::egg::GetMemoryBalancer() + 17559
    3 com.adobe.AfterEffectsLib.framework 0x00000001004aece3 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 43347
    4 com.adobe.AfterEffectsLib.framework 0x00000001004af135 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 44453
    5 com.adobe.AfterEffectsLib.framework 0x00000001004b00e6 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 48470
    6 com.adobe.AfterEffectsLib.framework 0x00000001004b2dba PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 59946
    7 com.adobe.AfterEffectsLib.framework 0x00000001004b2e30 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 60064
    8 com.adobe.dvacore.framework 0x0000000102f466d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 163
    9 com.adobe.boost_threads.framework 0x0000000110df6ace thread_proxy + 158
    10 libsystem_c.dylib 0x00000001095f8772 _pthread_start + 327
    11 libsystem_c.dylib 0x00000001095e51a1 thread_start + 13
    Thread 56:: com.apple.audio.IOThread.client
    2 com.apple.audio.CoreAudio 0x000000010cc1670c HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
    3 com.apple.audio.CoreAudio 0x000000010cc1669a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
    4 com.apple.audio.CoreAudio 0x000000010cc14ad9 HALC_ProxyIOContext::IOWorkLoop() + 1161
    5 com.apple.audio.CoreAudio 0x000000010cc145bf HALC_ProxyIOContext::IOThreadEntry(void*) + 83
    6 com.apple.audio.CoreAudio 0x000000010cc14497 HALB_IOThread::Entry(void*) + 75
    Thread 0 crashed with X86 Thread State (64-bit):
    rax: 0x000000012edf5e58 rbx: 0x00000000000000af rcx: 0x000000011a23cc10 rdx: 0x000000011a23cc10
    rdi: 0x000000012edf5e30 rsi: 0x0000000000000000 rbp: 0x00007fff5fbf8230 rsp: 0x00007fff5fbf8200
    r8: 0x000000011a23cc10 r9: 0x00000001020e8a70 r10: 0x00007fff5fbf81b0 r11: 0x000000011a23cc10
    r12: 0x0000000000000001 r13: 0x0000000000000000 r14: 0x000000012edf5e30 r15: 0x000000011a23cc10
    rip: 0x000000010110c390 rfl: 0x0000000000010206 cr2: 0x00000000000001b7
    Logical CPU: 3
    Binary Images:
    0x100000000 – 0x100003fff +com.adobe.AfterEffects (11.0.2 – 11.0) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
    0x100008000 – 0x100034ff7 +libtbb.dylib (0) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbb.dylib
    0x10004b000 – 0x100059ff3 +libtbbmalloc.dylib (0) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbbmalloc.dylib
    0x10006d000 – 0x100079fff +com.adobe.boost_signals.framework (6.0.0 – 6.0.0.339847) <37FE0EE8-CE3B-499D-881C-7F6400B8384A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
    0x100091000 – 0x100094fff +com.adobe.boost_system.framework (6.0.0 – 6.0.0.339847) <18F38BB7-5529-1655-2E49-EDADB686460E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
    0x10009a000 – 0x1000a1fff +com.adobe.boost_date_time.framework (6.0.0 – 6.0.0.339847) <0065F9F7-91BA-E8F4-3DAB-52D7A157A850> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
    0x1000bc000 – 0x1001b8ff7 +hydra_filters (0) <4605CB0B-62A0-5BAB-D593-7DFB63F6042B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
    0x100257000 – 0x100271fff +image_runtime (0) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
    0x10029d000 – 0x10029dfff com.apple.Carbon (154 – 155) <372716D2-6FA1-3611-8501-3DD1D4A6E8C8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x1002a0000 – 0x1002a0fff com.apple.ApplicationServices (45 – 45) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x1002a3000 – 0x1002a4ff7 +ALOG.dylib (1) <1442F648-F885-64DF-C453-35232AC8EF19> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ALOG.dylib
    0x1002a7000 – 0x100d19fff +com.adobe.AfterEffectsLib.framework (AfterFXLib 1.0 – 1.0) <8A4A9D50-B020-D947-13F8-D79E2DF86057> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
    0x100f76000 – 0x100f76fff +AEFX.dylib (1) <8097A384-C863-85D8-D422-5C17BD185AFD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AEFX.dylib
    0x100f79000 – 0x101457ff7 +BEE.dylib (1) <0FB2C7AA-9BCD-C9F4-1B60-A6D3A2956C59> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEE.dylib
    0x101655000 – 0x101663fef +BEZ.dylib (1) <2CD80E9F-966D-FE0B-8322-3EBC2190FEAF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEZ.dylib
    0x101668000 – 0x101672ff7 +BM.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BM.dylib
    0x10167a000 – 0x1016c7fff +COR.dylib (1) <37F2DA01-28C8-3C73-2AED-D26FDC255A0B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/COR.dylib
    0x1016ea000 – 0x10170bfff +FILE.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FILE.dylib
    0x10171b000 – 0x101745fff +FLO.dylib (1) <4122DB96-6BE7-8991-C33F-959B1809EBA8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLO.dylib
    0x10174a000 – 0x1017defff +FLT.dylib (1) <4EDA3A1B-F3EC-1CA2-39F6-B27FF54697CF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLT.dylib
    0x10183c000 – 0x101842ff7 +LIST.dylib (1) <63408BFE-7A9C-9A43-7471-556E8981FF96> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/LIST.dylib
    0x101846000 – 0x101860ff7 +M.dylib (1) <9A87636F-A4D1-BD25-8EAD-CDBAF9AC49C4> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/M.dylib
    0x101868000 – 0x101889fff +MC.dylib (1) <2F043BC4-C0E5-1815-3E20-8A77548B938E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MC.dylib
    0x10189b000 – 0x1018fafff +MSK.dylib (1) <447FFF12-D5C7-EB97-7E67-0FF583584FBD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MSK.dylib
    0x10190d000 – 0x101957ff7 +OM.dylib (1) <1B933233-25FD-CFC9-95F2-B6561032834E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/OM.dylib
    0x10196e000 – 0x101992fef +P.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/P.dylib
    0x10199b000 – 0x101c5aff7 +PF.dylib (1) <247A78C0-A969-B67E-31FB-24A2F5F785BF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PF.dylib
    0x101c83000 – 0x101ef7fff +PIN.dylib (1) <5FE76C21-AA8D-1593-CD3C-419B505D2821> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PIN.dylib
    0x101f63000 – 0x101f7dfff +PLUG.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PLUG.dylib
    0x101f8a000 – 0x101fa0fe7 +PR.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PR.dylib
    0x101fa9000 – 0x101faffff +PREF.dylib (1) <2E9B69A1-46B4-A690-28CE-F322BDC7DE08> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PREF.dylib
    0x101fb4000 – 0x101fd0fff +RG.dylib (1) <7557C627-4230-C25E-B766-90ECB480663D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RG.dylib
    0x101fdc000 – 0x101fdeff7 +RI.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RI.dylib
    0x101fe1000 – 0x101fe2fff +RND.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RND.dylib
    0x101fe9000 – 0x102049fef +SLU.dylib (1) <1F3BA216-5D4E-F77E-C5B4-B402B52DC097> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SLU.dylib
    0x10206e000 – 0x10208fff7 +SND.dylib (1) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SND.dylib
    0x102099000 – 0x10209bfff +STR.dylib (1) <25695631-D76F-961B-5F7D-1A805C1DF942> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/STR.dylib
    0x10209f000 – 0x1020a2fff +T.dylib (1) <360CFA0A-23B4-8628-56F3-37009A3C81F6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/T.dylib
    0x1020a6000 – 0x1020e7fff +TDB.dylib (1) <2550BC56-4069-91C4-4C77-1C70974C9F51> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TDB.dylib
    0x1020fb000 – 0x10282dfff +TXT.dylib (1) <5C3E70CD-7CB5-A2F9-A9D1-756B965C20B5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TXT.dylib
    0x102b5a000 – 0x102ba6fef +U.dylib (1) <3D08B211-20FB-E402-EAC8-3B9E7776D1DD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/U.dylib
    0x102bc2000 – 0x102bc6fff +VAL.dylib (1) <72374B38-F681-593B-D0FD-A66A54B3242F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VAL.dylib
    0x102bc9000 – 0x102c9bff7 +com.adobe.exo.framework (6.0.0 – 6.0.0.339847) <222A4842-F688-B0C0-503D-940699E12EDC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
    0x102dff000 – 0x102e25fff +PREM.dylib (1) <93D84D5E-2BA7-298B-DF43-9B7107DD97F1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PREM.dylib
    0x102e39000 – 0x102e8dff7 +FRP.dylib (1) <9563D99A-20A8-DA39-0299-CCF1CC14421B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FRP.dylib
    0x102eac000 – 0x10307bfff +com.adobe.dvacore.framework (6.0.0 – 6.0.0.339847) <67FC0E7D-C45D-F28F-F244-14419939D546> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
    0x103288000 – 0x1036f0fff +com.adobe.dvaui.framework (6.0.0 – 6.0.0.339847) <5C9E177B-42B2-9A2A-913E-DF8139CDAEB7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
    0x103c61000 – 0x103d19ff7 +com.adobe.dvaworkspace.framework (6.0.0 – 6.0.0.339847) <64BE690A-0382-D378-2D29-C745338715BE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
    0x103e26000 – 0x103e4afef +com.adobe.dvaunittesting.framework (6.0.0 – 6.0.0.339847) <3B4AD9EB-54D5-F899-0D84-581502C3C6B7> /Applications/Adobe Aft
    Roland R. kahlenberg replied 12 years, 9 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    December 12, 2013 at 12:54 pm
    Paul, try the Adobe AE Forum, they’re much better at stuff like this.
    Good Luck
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
