Activity Forums Apple Final Cut Pro Legacy AE/FCP round trip time code issue
  • AE/FCP round trip time code issue
    Posted by David Schneider on March 21, 2008 at 8:58 pm
    I’ve done this many times before, but this is the first time I’ve run into this problem. Honestly, I’m not sure if this is an issue with AE or FCP, but I suspect the latter, which is why I pose the question here.
    I’ve exported a short clip (a little under 2 seconds long) from FCP, using the current settings (DV NTSC, 29.97 FPS). I bring it into AE, where I can see it’s still 29.97. I do my work there, render it, then export it as a Quicktime, maintaining the settings, and I can SEE it is still set to 29.97.
    It exports, but when I import it back into FCP… it’s arriving as 23.98 FPS! If I open that same clip up in Quicktime player, the inspector shows me that it is in fact 29.97. So why is it arriving in FCP incorrectly?
    Anyone have a clue? I’m really pulling my hair out here. Thanks for any help!
    David Schneider replied 18 years, 6 months ago 1 Member · 1 Reply
  • David Schneider
    March 21, 2008 at 9:09 pm
    And I realize now my subject line is a little misleading… this is a frame rate issue, not really a time code issue.
