Activity › Forums › Adobe After Effects › AECS3 not refreshing video….HELP please!
Posted by Martin Banks on September 1, 2008 at 5:00 pmHi,
I’m having issues with AECS3. I’m using it on an iMac Intel Core 2 Duo 2.4GHz desktop with 2GB ram, running Leopard 10.5.The problem that ocours with AE is that occasionally some of the video clips in the timeline will not refresh if I scroll through it, or render it.
The video frame will freeze, however the motion applied to the video clip is not affected. If you need me to be clearer with that then please let me know.
I have tried closing and opening AE, which sometimes helps, however sometimes when I open it it’ll take no time for the same thing to occur.
Also there have been issues with my RAM preview, where I have not been able to preview more that 25 frames. Even when the quality settings are even on the lowest setting, and all that the section of the composition I am trying to RAM preview contains is a simple video clip.
I had previously been using After Effects 6.5 which I have had no trouble with for a long time. Now having had this problem with AECS3 I am hoping that I will not have to go back to 6.5 and start to rebuild the project again.
As I am new to CS3 I was wondering if there is anything I am missing in the setup which may be causing these problems.
ANY help with this problem is greatly appreciated as it is completely foxing me!!!
Thanks in advance.
MartinStoney El-abd replied 17 years, 9 months ago 4 Members · 13 Replies -
Immanuel Morales
September 2, 2008 at 2:14 amsometimes i have this problem if i am running low on RAM, normally i do the following..
Edit/Purge/All
then..
Edit/Preferences/Memory and Cache
– here i click ‘clean database and cache’that’s it.
however, you may want to check your ‘Maximum RAM Cache Size’ and be sure that it is not set too low. you may have set it low to get your max multiprocessing capabilities but for this you also need sufficient RAM (4-5GB is good for an 8 core machine, 2GB will give you about 2-3 cores i think)
Darqlight on the Rise…
Pollux Kendall
September 2, 2008 at 7:49 amI’m also having this exact problem, except I’m on a Macbook Pro 2.4 C2D with 2 GB ram, Leopard 10.54.
The video clip seems to get stuck on a frame when previewing, or will alternative back and forth between that stuck frame and the frame it’s suppose to be on. The result is a very mangled-looking clip.
I’ve tried Purging Image Cache/Video Memory and tried Cleaning Database/Cache. This does reset everything but if you preview it will get mangled again.
I’ve tried playing around with the Max RAM cache size and Max Memory Usage, but I haven’t yet been able to fix it. Let me know if you find a solution.
Thx,
Kendall -
Pollux Kendall
September 2, 2008 at 9:47 amDave LaRonde seems to have the right of it in this thread.
https://forums.creativecow.net/thread/2/929328
Seems to be do to the type of file imported into AE. AE CS3 can’t handle frames with incomplete information very well it seems. I’ve tested by converting a .mov with photo jpg compression into .mov with animation comp. and the stuck frames disappeared. Though, this is just a work around, I feel.
Martin Banks
September 2, 2008 at 9:48 amThanks for that information, it’s something I didn’t know about and therefore consider!
I purged all, and then cleaned the database cache, and then tried to make movie so I can watch back what I have done, however the same issue occurred.
I checked my maximum RAM cache size however I don’t know if it is set at a suitable setting. It is currently on 60% = 1.2GB of 2GB RAM. My Max Mem Usage is set to 120% = 2.4GB and the enable disk cache is off. Do these sound like reasonable settings?
Any help would be greatly appreciated.
thanks again,
Martinhowever, you may want to check your ‘Maximum RAM Cache Size’ and be sure that it is not set too low. you may have set it low to get your max multiprocessing capabilities but for this you also need sufficient RAM (4-5GB is good for an 8 core machine, 2GB will give you about 2-3 cores i think)
Martin Banks
October 27, 2008 at 10:38 pmWas the most efficient work around?
I went back to 6.5 and used that for the project, and now it’s almost done it is refusing to open, it just crashes straight away. I have tried deleting the preferences, and also uninstalling it and reinstalling but still the same.
So I am back to using CS3, and I’m still having the same problem with the video freezing. So it looks like I’ll have to re-compress the original movie clips that I then imported into the comp?
Martin Banks
October 28, 2008 at 10:42 amPlease excuse my lack of knowledge as well, but would you be able to suggest a codec that doesn’t use temporal compression? As I am unaware of what that is, and I need to convert my original clips.
I find that quite a shock that Adobe would lead you to believe that it supports HDV, Open GL and mp3s when it actually doesn’t, is that not false marketing and if not that then just lies?
Thanks for your help,
Martin Banks -
Martin Banks
October 28, 2008 at 3:16 pmI used the animation codec at 100% the first time I exported the original clips. They were blue screen dancers. So the files I imported into AE where .mov clips using the animation codec with an alpha background. These are the clips that are freezing in After Effects.
Before you replied to my last thread I had been through and exported the original clips with no compression instead of using the animation codec. This seemed to have worked when I first imported one of the uncompressed clips, so I went back and did all of them, and have just imported them all into AE.
However now the videos are just black, with the occasional frozen screen. I really don’t understand how I can correct this. It is proving to be a huge pain, especially as the deadline for the job is on Saturday!
Thanks again for your help,
Martin -
Martin Banks
October 28, 2008 at 4:27 pmSorry if that was worded incorrectly, what I did originally was:
Shoot dancers against a bluescreen on DV.
Capture in DV clips using Final Cut Pro
Import clips into AE and use Keylight to remove bluescreen with good results.
Export the clips out of AE using the animation codec at 100% with Alpha.No other effects were applied.
These clips were then imported into AECS3 to start animation on but they kept freezing and I couldn’t figure it out. During my testing to try and figure out why they froze up I imported them in to AE6.5 an it worked fine, so I used AE6.5 to build the animation. No problems with that, looking great and working fine. Then at the start of this week AE6.5 refuses to open, it just crashes even before the loading screen comes up. Tried deleting prefs, no joy, tried uninstalling and reinstalling, no joy. Had a look at a lot of forums too but I seem to have too many problems with the project to be able to let me brain focus on one this at a time.
So I open up the project in CS3 to see if I can fix the freezing, and that is as far as I have got. Still a minute or so of animation to complete and then to export the final clips, IF I can get this freezing to stop.
From the above, would it be advisable for me to export the alphad clips using a different compressor or should it work with the Animation one, or do I need to go further back to the original clips to stop this happening?
Why does technology fail me right when I need it most, or when I thought this week would be easy, just finish the animation in 6.5 and then have the rest of the week to render. Alas it was not to be so.
Thanks for your suggestions, I feel like I am at a total dead end and I’m not supposed to finish this project!
Martin Banks
October 28, 2008 at 5:02 pmI will give turning off the Open GL a try and see what happens from there.
As far as the keying job goes, that is all good. I know you are supposed to get terrible results from keying DV, any maybe the results are a lot poorer than what I would have had if I had shot on something else. However keylight, plus some other bits and bobs have worked wonders. There are only a few fine points in the video where you notice a slight edge to one of the dancers. They are on a black background and there is a fair amount of animation going on so the eye is not focused on the dancers the whole time. Well, I am happy with it anyway and I tend to have high standards.
Thanks for all your help Dave. I’ll let you know if turning off the Open GL works. If not it looks like I’m going to have to dig out my old G4 laptop with 6.5 in and try and sort the final bits in that!
Martin
Martin Banks
October 28, 2008 at 5:04 pmWell it appears as though my Open GL has been turned off the whole time anyway, and the adaptive resolution turned on, so it looks like I’m going to have to find my G4.
Doh!
Martin
