Activity › Forums › Adobe After Effects › AECS3 not refreshing video….HELP please!
Stoney El-abd replied 17 years, 9 months ago 4 Members · 13 Replies
Martin Banks
October 28, 2008 at 5:19 pmok, so maybe my terminology isn’t up to scratch…..another explanation:
The original clips shot against blue screen.
Imported into AE and blue screen removed.
Rendered out of AE with the alpha channel (transparent background(?)) so that parts of the animation that are in 3D can move around the dancers.
I rendered them out so that whilst building the animation around the clips I would not have to wait for all the effects and keylight plugin to RAM preview as well.
So once they are into AE with the transparent background I animated all my bits and bobs, the 3D parts moving around them.
I did add a black solid to the lowest layer of the comp (behind all the dancer clips and animated layers) once the majority of the animation was done.
I have looked in the preferences menu and I only see an Open GL option for previewing, even though this has been off the whole time my previews still hang. I’m guessing the render option to turn if off comes up somewhere in the make movie window, I’ll have a search in a bit.
Just about to load the project on the G4.
Thanks again Dave,
Martin -
Martin Banks
October 28, 2008 at 5:54 pmI only used FCP to capture the footage onto my computer, no editing o keying was done what so ever in FCP. After the footage was on my hard drive everything else has been done in AE.
Sounds like I should’ve brushed up on my 3D before starting it. Oh well, looks like it’s going to b a VERY long few days now that I am back on the G4.
martin
Stoney El-abd
December 18, 2008 at 10:05 amThanks for the tips Mr. LaRonde. I have a similar problem when I render out to dv Ntsc at 23.98 some downsized/downrezzed HVX 960×720 23.98 footage. I have a 8 Core MacPro 3.0, 6gb ram outfitted with both the ATI Radeon HD 2600 XT 256 VRAM and NVIDIA GeForce 8800 GT 512 VRAM cards. My DELL 2009W is attatched to the latter with a resolution of 1680×1050@60 Hz. It’s a work comp so that’s how they ordered it.
I just edited a music video 2 weeks ago with no problems, same type of footage from the HVX. I was even able to get the multiprocessing to speed up renders until towards the end that started getting hincky. I then cut it (mp) off and had no further problems. Then, this week as I was chuggin along, I started getting the weirdness of my undo/redo being greyed out, “AfterEffects needs at least 2 frames for playback” warnings during ram previews, my renders to dv-ntsc all freezing on the last frame of the render and audio being in sync when it feels like it when I bring it back to FCP 6. I had been using the workaround of just canceling the render and bringing the movs into FCP. I don’t know what I did to get the out of sync files to render properly when I did fix the problem. I did it all, emptying every cache I could in AE, restarts, changing the ram cache and % ram dedicated to AE and FCP. But today the buggaboo doesn’t wanna let me finish my video. Yesterday everything was fine.
I did not know about the lofty OpenGL claims of Adobe about AE, I was stoked and thought I was driving a nuclear sub after being stuck on a G4 PB the last 4 years. Do you happen to have a FAQ posted anywhere with your suggested Mac Pro configurations? Thank you and sorry for the long explanation.
