Activity › Forums › Adobe After Effects › AE workspace stuck under menu
  • AE workspace stuck under menu
    Posted by Alex Kuzelicki on September 12, 2007 at 2:02 pm
    I’m the world champion at accidentally doing weird things with AE.
    Every now and then I’ll somehow drag the AE workspace up and under the top menu. Once it’s there, there’s now way to grab it and drag it back down (to a usable position) again.
    My only alternative is to close down and restart AE, which resets the workspace.
    Just wondering if there’s a way to easily reset it, with the main menu perhaps (as the “Workspace” option is usually stuck up under it)?
    I know this is probably not a very common problem but, like I said, I’m the champion…
    Thanks in advance,
    ALEX
    Alex Kuzelicki replied 19 years ago 2 Members · 2 Replies
  • Kevin Camp
    September 12, 2007 at 2:37 pm
    from the window menu, you can set workspaces… you could try choosing a workspace from there… will that work?
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Alex Kuzelicki
    September 12, 2007 at 3:07 pm
    Cool.
    Thanks guys.
    Will try out the suggestions.
    Appreciated,
    ALEX
