Activity › Forums › Adobe After Effects › AE Won’t Render my 1080p at 29.76 composition!
  • AE Won’t Render my 1080p at 29.76 composition!
    Posted by Trey Yoder on November 20, 2010 at 3:39 am
    I have a project set to 1080p at 29.76, thanks to Adobe Media Encoder. I’ll import into after effects and check the comp settings and it is set like it should be. But when i render to .wmv, it changes it back to 24 fps. Any ideas? Please help, thanks.
    Trey Yoder replied 15 years, 10 months ago 2 Members · 2 Replies
  • Eric Chard
    November 20, 2010 at 7:17 am
    When you render it to .wmv, what s/w are you using to check the frame rate?
    “Putting the HARM in ‘harmonica’ since 2005.”
  • Trey Yoder
    November 20, 2010 at 9:10 pm
    Oops, i made a mistake. Yea, i meant 29.97! And when i finish rendering i’ll look at the properties of the file and it will be 24. And it cuts the file size down too. I did however try using a different format (.avi) that fixed the problem but i want to render it in a .wmv, due to the size.
