Activity Forums Adobe After Effects AE to completely edit video?
  • AE to completely edit video?
    Posted by Steve Wonder on December 13, 2007 at 2:28 am
    I tend to use Vegas to edit videos, but I just got into AE and it seems more flexible in certain parts (if I can learn it). Can AE be used to edit videos by itself, or is it mostly used just for certain parts of videos?
    Sebastien Gravel replied 18 years, 9 months ago 3 Members · 2 Replies
  • Steve Roberts
    December 13, 2007 at 4:43 pm
    To add to Dave: “It’s a pain. Don’t do it.”
    Edit the timing of your program in your NLE (Vegas), using placeholders for the effects shots if necessary. Once the timing is ***locked***, render the appropriate shots that need effects, then import those into AE. Work the magic, then render the shot and drop it back into the timeline of your NLE. That’s one way of working.
    To use a metaphor, NLEs are “horizontal”, AE is “vertical”. Mostly.
  • Sebastien Gravel
    December 13, 2007 at 5:47 pm
    Especially with Vegas 8, you can work at 8, 16 or 32 bits, so really there is no “loss” between render if used in 16 or 32 bit mode.
