Activity › Forums › Adobe After Effects › AE to Boujou 5.0 (High FPS footage)
  • AE to Boujou 5.0 (High FPS footage)
    Posted by Zam Azomi on March 18, 2017 at 6:45 pm
    Hey! (sorry for the london btw)
    So I have some footage that i want to track with boujou. Now the thing is that the footage is game footage from Call Of Duty 4 that is recorded at 600 fps since i use time-remapping to ramp the video (it goes from a speed of 300% to 20% in the matter of frames) between 2 sync points so therefore i need a high fps.
    Anyways can i render the 600fps footage as 60fps/30fps in jpeg to import in boujou or will that just mess up the timing of the tracking?
    Or do I have to like time stretch the 600fps clip by 10 (time-stretch: 1000) so that I get 60fps?
    If it’s too any use: I will render the final video from AE in 30fps to upload to youtube.
    Zam Azomi replied 9 years, 6 months ago 1 Member · 2 Replies
  • Zam Azomi
    March 18, 2017 at 10:30 pm
    The clip is 600 fps:
  • Zam Azomi
    March 19, 2017 at 9:04 am
    I just dragged the 600 fps footage into the comp button on the project panel and it makes a new comp at 600 fps with the 600 fps footage inside it, but if you open the 600 fps comp settings and just click ok it will change the fps to 99. So just gotta make sure you don’t touch that, and if you do just undo until you see that it’s 600 fps in the project panel.
