Activity Forums Avid Media Composer AE to Avid
  • AE to Avid
    Posted by Jana on October 2, 2005 at 2:59 am
    Hello,
    I am having trouble with the following workflow:
    I rendered my composition from AE, i changed my render settings to omf, i rendered the file, but when i go to export, there is no export as omf, there is nothing similar to that? How do i export my omf render out of AE?
    This is hopefully just a simple thing I am missing…any help would be greatly appreciated!
    Jana
    Don Logan replied 20 years, 11 months ago 4 Members · 6 Replies
  • Jana
    October 2, 2005 at 3:16 am
    Okay,
    I figured out that when i render in omf, ae automatically saves to a certain folder…the new problem is that when i try to render as omf, i get an error saying the dimensions aren’t right the correct error is
    “AEGP Plugin OMF output dimensions do not match selected omf format (720×480) expected”.
    Any suggestions as to what i can do to fix this?
  • Alex Alexzander
    October 2, 2005 at 7:16 am
    Select Composition, Make Movie
    Select the Output Module: Lossless
    And then select Format, OMF.
    -Alex
  • Alex Alexzander
    October 2, 2005 at 7:23 am
    It means the composition you created at the start is likely smaller than 720 x 480. Use the pull down menus, and select Composition, Composition Settings. Then change the comp settings to 720 x 480. Try to export again as OMF.
    -Alex
  • Jana
    October 2, 2005 at 12:15 pm
    Thank you Alex
  • Jiggs_67
    October 4, 2005 at 5:49 am
    I’ve been rendering quicktime movies at best settings out of AE. Then Avid imports the movie and converts it to OMF. If there is a better way I’d love to know but this has worked just fine.
  • Don Logan
    October 5, 2005 at 2:13 am
    I would export it as a quick time movie.
    Can’t remember off the top my head what my AE render settings are but I know unless your using AE6.5 it does not play well with OMF.
    Hope this helps
    RD
