Activity Forums Adobe After Effects AE Titles into Premiere are Jagged??
  • AE Titles into Premiere are Jagged??
    Posted by Karl Williams on August 18, 2009 at 11:07 am
    Hi folks i am sure this is a simple problem but im struggling to find what i need in the boards.
    I have a HDV 1080i25 (50i) sequence and i am trying to dynamic link a clip into After Effects to add titles. This Works and the title looks fine without “Toggle Pixel correction” checked but when i do check it, it looks jagged and subsequently the same when back in PP CS4 any ideas?
    Many Thanks
    Adolfo Rozenfeld replied 17 years, 1 month ago 2 Members · 1 Reply
  • Adolfo Rozenfeld
    August 18, 2009 at 1:43 pm
    When you enable PAR correction preview with that button, AE uses a lower quality filtering mode for Composition panel updates. This draft-like mode is only affects previews while working in AE with PAR correction turned on. It doesn’t affect the actual quality of AE’s output.
    Adolfo Rozenfeld · Adobe
