Activity › Forums › Adobe After Effects › AE supers look bad in ProRes422 timeline
  • AE supers look bad in ProRes422 timeline
    Posted by Jerry Sneede on February 5, 2010 at 10:49 pm
    When exporting supers in AE in the Animation codec with alpha, they look great in an Uncompressed FCP timeline, but jaggedy in a ProRess timeline. I’ve also tried PNG with alpha with the same outcome. Anyone know how to get around this?
    – js
    Jerry Sneede replied 16 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • Tim Vaughan
    February 5, 2010 at 10:55 pm
    Yeah, make sure your window viewer is at 50% or 100%. If in “scale to fit” mode, it will look jaggedy. Problem is NOT with lossless + alpha or Prorez. Use it all the time (Also try ProRez 444 with Alpha to coincide with the prorez footage/timeline. File sizes are much smaller, but look fantastic)
    Tim
  • Jerry Sneede
    Ok, this is strange. It seems that sometimes the supers look bad, and sometimes they don’t. I made a new timeline, also ProRes, and copied everything from the original ProRes timeline to it, and the supers from AE were perfectly sharp. Strange.
  • Jerry Sneede
    February 5, 2010 at 10:56 pm
    Tim,
    Yes, the window size was not an issue. I had both windows at 100%.
  • Jerry Sneede
    February 5, 2010 at 10:57 pm
    Tim,
    Also, the problem persisted in the quicktime output also. I just don’t know what the difference between the two timelines is. They are the same size (1920×1080), same framerate, same codec.
  • Jerry Sneede
    February 5, 2010 at 11:02 pm
    Tim,
    I’m not seeing the ProRes444 option in my AE. Where can I find this?
  • Jerry Sneede
    February 5, 2010 at 11:10 pm
    Dave,
    It’s not a field thing. The fact that it looks good in one timeline and not another identical one is the strange thing.
    Also, I figured out that ProRes444 comes with stuido 3, it’s not in 2. Another good reason for us to upgrade here.
  • Jerry Sneede
    February 5, 2010 at 11:18 pm
    Dave,
    Yup, it turns out the bad timeline had a field dominance of none, the good one of Upper. I’m not sure how I ended up editing in a timeline with no field dominance, I suspect it came from dropping in some footage and saying Yes to making the timeline change to match that footage.
