Activity › Forums › Adobe After Effects › AE software
  • David Bogie
    May 13, 2009 at 8:21 pm
    Best to check with Adobe’s marketing site for AE and run a search on the AE forum at Adobe. Don’t just post the question, try searching first since you’ve already posted it here.
    Should work fine if it will work in OS10. If you need OS9, all bets are off. Time to upgrade, you’re going to love CS4.
    bogiesan
  • Johnsabbath D’urzo
    May 14, 2009 at 12:52 am
    i searched and some say it will work but only on one processor and some say it will not power pc programs will not work. has anybody hear tried this?
  • David Bogie
    May 14, 2009 at 2:30 pm
    [johnsabbath d’urzo] “i searched and some say it will work but only on one processor and some say it will not power pc programs will not work.”
    There is your answer: “No.”
    Logically, any question that cannot return an answer of YES for every test has a steady state of NO.
    If “no” is not good enough for you, you buy the machine and find out for youself.
    bogiesan
