Activity Forums Adobe After Effects AE slows down with each render
  • AE slows down with each render
    Posted by James Hoback on August 9, 2011 at 2:52 pm
    Greetings, I’m having trouble with After Effects slowing down after each render. Even with Multi-core rendering turned on, the render times keep getting longer. I have to reboot my computer after 3 or 4 renders to clear everything and get my original speed back.
    I’m not sure what to do about this. I’ve cleared caches and such, but to no avail. Is there any way to remedy this problem?
    After Effects CS5
    Mac Pro 5
    Quad-core Intel Xeon 3.2 GHz
    10 GB ram
    Nvidia GeForce 8800 GT
    I also have a bunch of plugins installed, not sure if this would cause a problem.
    Evgeniy Foucault replied 14 years, 11 months ago 3 Members · 3 Replies
  • Martin Sautter
    August 9, 2011 at 3:02 pm
    Hi James,
    I have experienced the same problems. I started to use the bg render script at aescripts.
    https://aescripts.com/bg-renderer/
    That didn’t solve the original problem but ae doesn’t slow down over time and you can continue work while rendering….hope that helps until u find a better solution..
    cheers
    http://www.martin-sautter.com
  • James Hoback
    August 9, 2011 at 4:56 pm
    Thank you for the quick response. I have used that script with great love, but I’m hoping to address the current situation and solve this problem.
    Take care.
  • Evgeniy Foucault
    October 5, 2011 at 1:15 pm
    any body solved this ? may be some ideas?
    i have same problems on windows 7, core i5, 16gb ram.
    even on clean instaltion without any external plugin.
    only rebooting helps.
