Activity Forums Adobe After Effects AE Shortcut wont open media encoder (ctrl+alt+M)
  • AE Shortcut wont open media encoder (ctrl+alt+M)
    Posted by Jeroen Rommelaars on August 2, 2018 at 7:53 am
    Hey guys,
    I was hoping someone knows a fix for this issue.
    I just built a new computer, did a clean install of win10 pro, and a clean install of all adobe apps, including AE18 and Media Encoder 18.
    The only problem I have is that the shortcut to add the current comp to the media encoder queue (ctr+alt+m) doesnt do anything.
    I checked in the shortcut menu, and yes, it is listed.
    Anyone have a fix for this very silly issue? Its kinda timeconsuming to have to click edit->add to queue for each comp when i have to render a load of comps ????
    ps. this issue is apparently a bit more common, as can be seen by this thread on the official forums. https://forums.adobe.com/thread/2395804
    Of course, I posted there as well, but I have much higher hopes of a quick response on these forums than on the official ones ????
    pps. Even a fresh install of both AE and ME didnt work.
    ppps. Adding a custom shortcut to the command (ctrl+alt+SHIFT+m) makes it work again. Not ideal, but ey, working for now 🙂
    Any help is much appreciated!
    Cheers!
    Neal Strydom replied 8 years, 1 month ago 2 Members · 1 Reply
  • Neal Strydom
    August 6, 2018 at 1:44 pm
    I thought this was just my PC doing this for some time, but then I saw it was permanent on my end and now I just use the menu.
    I think it will be fixed in a bug-fix patch. Or I would hope so. My advice would be to just hang ten until they roll out a fix and like you said, you did report it, so they should see to it in their next patch roll-out.
