Activity Forums Adobe After Effects AE shadows in Avid
  • AE shadows in Avid
    Posted by Mark Suthard on August 16, 2006 at 7:48 pm
    Whenever I try to give a graphic a soft edge or apply a shadow to a graphic in After Effects, it has a strange look to it when I bring it into the Avid. The Shadows will sometimes look grey. If I try to add a softness to the edge, an almost white background will show up behind the graphic. I use the Animation codec in After Effects to render and other than these two problems everything else looks amazing. When I bring into the Avid I have both options for 609 checked. I hope this doesn’t sound too confusing.
    Lars Bunch replied 20 years ago 2 Members · 2 Replies
  • Lars Bunch
    August 16, 2006 at 7:52 pm
    This is a premultiplication error common when looking at an animation with a soft alpha channel in an editing system.
    When you render the animation, in the output module, obviously you will be setting the “Channels” to RGB+Alpha. Under this, set color to “Straight – Unmatted”
    The resulting animation will look horrible when viewed in Quicktime, but will mask properly in the Avid.
    Hope this helps.
    Lars
  • Lars Bunch
    August 17, 2006 at 2:35 am
    Also,
    You might want to go to the Avid web site and download the Meridian codec if you are using one of the more recent Avid systems. Importing a Meridian animation goes much faster than importing something rendered with the Animation codec.
    Lars
