Activity Forums Adobe After Effects AE Settings for SD 16;9 Composition to be Used in Avid
  • AE Settings for SD 16;9 Composition to be Used in Avid
    Posted by Tim Scarpino on April 23, 2007 at 2:48 pm
    Greetings all,
    Wondering what composition settings anyone uses to create a SD project in AE that will be imported into MCA for final output to a 16:9 monitor.
    With those settings, are you able to create a .omf file when rendering your movie in AE, or are the settings such that you have to make it a .mov file?
    Is there a preset in AE that makes this easier?
    You can see where were going, so any guidance would be appreciated!
    Tim Scarpino
    Nate Vander plas replied 19 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    April 23, 2007 at 3:47 pm
    as far as ae preset try d1 widescreen. the comp will be 720×486, but with a 1.2 pixel aspect to make it 16×9. this is the typical way to do sd 16×9 and the way media would be prepared for a widescreen dvd.
    i think the omf should work, but you can always render a mov file too. just duplicate the output module then set one to render omf and leave the other at lossless. it won’t effect the render time, you’ll just get 2 renders.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Nate Vander plas
    April 24, 2007 at 12:37 am
    I believe Avid’s widescreen dimensions are 853 x 480, which is unique to Avid and frankly rather annoying.
