Activity Forums Adobe After Effects AE Scripting: Getting info from a text file
  • AE Scripting: Getting info from a text file
    Posted by Øyvind Veberg on June 7, 2005 at 6:26 pm
    Hi!
    I’ve been reading about scripting on Dan Ebberts VERY informative site http://www.motionscript.com. Particularly I found the article about creating text layers from a file very useful. However, I’m having some trouble getting AE to “behave” when there is a line break (and no text) in the file it is reading. What I want to do is make AE “skip” the “empty” line, and continue reading the file.
    An example of text to be read:
    Hello, world!
    This is a test!
    The line between “Hello, world!” and “This is a test!” is empty… If I replaced the line break with “-“, I got it working somehow with this code:
    var text;
    while (!myFile.eof){
    text = myFile.readln();
    if(text==”-“)
    myFile.readln();
    else
    myComp.layers.addText(text);
    But this not very efficient, since I would have to replace every line break with “-“…
    As you guys might have figured out, I’m not a scripting expert, but I know some of you are… Hope you can help me out (It’s probably very basic…).
    Cheers!
    Øyvind Veberg replied 21 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 7, 2005 at 6:57 pm
    Try it this way:
    var text;
      if(text.length != 0) myComp.layers.addText(text);
    That should detect the line breaks.
    Dan
  • Øyvind Veberg Create COW Profile Image
    Øyvind Veberg
    June 7, 2005 at 7:06 pm
    Hi!
    Thanks, Dan! It did the trick!
    Cheers!
