Activity › Forums › Adobe After Effects › AE script/comp crashing on render
  • AE script/comp crashing on render
    Posted by Joel Arvidsson on March 15, 2013 at 11:47 pm
    Got an ae comp/script that crash when render. It was an dynamic linked clip that i changed composite durantion on and extended it.
    I think this could be the reason for the crashing. The orginal do not crash. Im thinking it can be referensing the dynamic link still even thoe i saved it under a new name.
    Its a simple comp with some roto and paint job. I dont think its the paint operattion but It would be my second or third guess. When it crash it sometimes wine about the exposure effect.
    Any suggestions. I will force this render tomorrow one way or another.
    Cheers
    Joel
    joelarvidsson@gmail.com
    Todd Kopriva replied 13 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Todd Kopriva
    March 16, 2013 at 2:33 am
    We need to know a lot more if we’re going to help you. Please provide answers to the questions listed here:
    “FAQ: What information should I provide when asking a question on this forum?”
    After Effects team blog
  • Jerome Carter
    March 16, 2013 at 10:32 am
    I have some experience with scripting and after effects, if you want to share your code, I can review for possible syntax, construct problems.
  • Joel Arvidsson
    March 16, 2013 at 4:31 pm
    Jerome, that was very kind. Sorry I did not mean scripting.I meant the ae projekt file so no scripting.
  • Joel Arvidsson
    March 16, 2013 at 5:06 pm
    Here is some more data Todd.
    I use cs6 ae with the latest update.
    Windows 8 proffesional
    red r3d 4k file is the source clip.
    Some times ae crashes and sometimes I get a error like this
    after effect error: crash in progress. Last logged message was:<6624>
    <0> Vid rate ratios min, max:1,1
    or
    After effects error:crash occoured while invoking effect plug-in “Exposure”.
    or.
    After effects error:crash occoured while invoking effect plug-in “indiviual levels”.
    The problem only comes when im rendering.
    I have not had any problem with ae crashing and alot of clips have been rendered with very similar setup.
    I have just installed the a blackmagic card but the my first version of this comp have no render probleme. Only the one
    i extended the compostion time on to make the clip longer.
    No problems on ram previews at all.
    No multiple frames rendered simultaneously.
    I just think this has to do with that the clip was dynamic linked from premiere to ae. Then I got a to extend that clip later in ae with composition settings time. I think 90% of all error in ae is related to the dynamic link so thats my guess.
  • Joel Arvidsson
    March 16, 2013 at 5:28 pm
    Its even in ram previews now… didnt se that yesterday
  • Joel Arvidsson
    March 16, 2013 at 6:31 pm
    1/4 ram preview does not crash, and I know I did 1/2 before. But full crashes.
  • Joel Arvidsson
    March 16, 2013 at 7:32 pm
    Never found the problem. Had to render it out in segments. Atleast its done.
  • Todd Kopriva
    March 17, 2013 at 12:22 am
    I’m glad that you were able to at least get your project done. Please submit a bug report here so that we can look into the issue:
    https://www.adobe.com/go/wish
