AE script to set anchor point to position of another layer?
Anyone know of a script or simple technique to set the anchor point of a layer to the position or anchor point of another layer (without moving the position of the layer)? For example, if I have a complex 3D scene and I decide that I need to rotate a 3D object around the position of another object, accurate placement of the anchor point can be quite tricky and time consuming (at least I’m finding that).
A script that allows you to select the layer you want to change the anchor point of and the target layer (and maybe even gives you the option to set the anchor to the outside edge/corners of the layer or the anchor point itself) would be amazing.
Any ideas?
Many thanks,
Paul.
