Activity Forums Adobe After Effects AE Render Times
  • AE Render Times
    Posted by Mike Moss on November 28, 2010 at 4:54 am
    I have a pretty powerful machine, yet my AE render times and RAM preview are horrible!
    Any ideas on speeding things up? I dont have much money to spend on higher grade parts…was thinking more in the internal AE settings.
    I only get 1-3seconds of RAM preview on a medicore(Medicore regarding the complexity of the comp) comp. And rendering usually takes 3-4hours for a 3min h.264 .mp4 video…
    Any Ideas?
    My Machine is listed below:
    Intel Core i7 950
    6GB DDR3 Memory
    Asus P6X58D Premium Motherboard
    GeForce GTS 450 GPU
    Win7 64bit
    AE CS3
    Walter Soyka replied 15 years, 10 months ago 3 Members · 2 Replies
  • Tim Vaughan
    November 28, 2010 at 12:53 pm
    AE could certainly use a LOT more RAM. I currently have 24g’s, and it sucks it up pretty quickly. Also, you are using the h.264 codec, a codec that is NOT ideal for AE. Run a search for all the specs here in the cow, but I’d highly recommend converting the codec to something a little more native to AE, such as an avi. (Not sure what codecs you have installed, and I’m on a Mac where everything gets converted to ProRez422.)
    Tim
    Tim
  • Walter Soyka
    November 28, 2010 at 6:57 pm
    With regard to the slow rendering: if you have multi-processing enabled, turn it off. As Tim said, you don’t have anywhere near enough RAM to feed multiple cores. Multiprocessing launches multiple instances of the renderer, each running on its own core, and each instance requires its own RAM — at least 2GB, and preferably 3 to 4 GB per instance. Of course, the operating system and any other open applications require their own RAM as well. I’d equip a quad-core system with at least 16GB of RAM.
    Also, I agree with Tim about h264 — rendering directly to h264 isn’t a good workflow. h264 really benefits from multipass encoding, so it’s better to render to a lossless intermediate (like Animation or PNG codec Quicktime movies) and then compress that to h264.
    As for the length of your RAM previews, that depends on a few factors: your memory preferences, the resolution of your comp, the color depth of your comp, your free RAM, and your version of After Effects. AE CS3 is 32-bit only, so it can grab a maximum of 4 GB of RAM for the application, all layer and image caches, and RAM preview (you can adjust this allocation in your memory preferences). CS5 is 64-bit, so it can access all the RAM in your system, allowing you much longer RAM previews (if you upgrade your memory).
    Walter Soyka
