Activity › Forums › Adobe After Effects › AE render of illustrator type blurry
  • AE render of illustrator type blurry
    Posted by Heather Crank on November 29, 2005 at 8:09 am
    I just rendered some illustrator files(outlined) with the animation codec and they are appearing blurry when I play the quicktime with the “present movie” setting. Any ideas how I can fix this? Is there a better codec for illustrator files?
    Thank You,
    Heather
    Heather Crank replied 20 years, 10 months ago 2 Members · 2 Replies
  • Steve Roberts
    November 29, 2005 at 2:33 pm
    Animation is basically a lossless codec, so it doesn’t get better than that when working in 8-bits-per-channel. (10-bits-p-c is currently overkill for many situations and won’t play smoothly on most machines)
    Soooo … have you checked “high quality enabled” in the Quicktime properties? Open the movie, hit cmd-J (ctrl-J on windows) and look for the quality setting.
  • Heather Crank
    November 29, 2005 at 7:26 pm
    I’ll try that now. Thank you sooooooo much for the suggestions.
    Heather
