Activity Forums Adobe After Effects AE Render Memory Handling
  • AE Render Memory Handling
    Posted by Francois Driessen on August 22, 2006 at 7:55 pm
    Doing a quick key in DVCPRO HD. However, as I render out, AE makes it to 2/3rds of the 7 second clip and then I run into the error: Could not create 1280×720 image buffer. (7::39).
    I have sat an watched Activity Monitor as AE eats away at the 5Gigs I have in my G5, until it used about 2,7Gigs and that ads up into the Inactive segment, and then the Error appears. Sure I have purged all, read up about color space, etc. But have rendered out MUCH larger & longer clips than this. Whazzup here?
    Francois
    >- e y e f l a m e .tv –< https://eyeflame.tv
    Francois Driessen replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
