Activity Forums Adobe After Effects AE Render Engine: Multiple Instances on dual processor cluster node
  • AE Render Engine: Multiple Instances on dual processor cluster node
    Posted by Alan Abrams on October 20, 2005 at 4:09 am
    Hello. I have two XServe cluster nodes that I’d like to set up as a render farm. They are both dual processor machines. In order to take advantage of as much CPU power as possible, is it OK to be running two instances of the render engine on each cluster node? will this even work? thanks!
    Barend Onneweer replied 20 years, 10 months ago 2 Members · 1 Reply
