Activity › Forums › Adobe After Effects › AE Render Crash
  • AE Render Crash
    Posted by Victor Nash on December 9, 2005 at 12:56 pm
    AE keeps crashing every 15frames or so when I render. The project is a 30second spot with HD footage bumped down to a 720 540 comp. It is quite motion graphic intensive! The work around is we are rendering 3frames and importing the Sequenced footage into Avid,.. and that is obviously a pain and time consuming. The computer we are using is a Xeon HP 3Ghz 3gigs of Ram. Im looking for people who have had similar problems, and possible solutions. Thanks
    vman
    Victor Nash replied 20 years, 9 months ago 2 Members · 2 Replies
  • Steve Roberts
    December 9, 2005 at 2:19 pm
    You might be running out of RAM. Try accessing the secret prefs by holding down the shift key when accessing the prefs — release shift when the dialog box appears. Try setting it to purge every 5 frames during Make Movie.
    Keep windows task manager open to watch your RAM usage if you like.
    Steve
  • Victor Nash
    December 9, 2005 at 10:12 pm
    Steve,
    You are the man. Thanks a bunch. It worked great.
