Activity Forums Apple Final Cut Pro ? regarding “a real-time preset to match broadcast specifications (Rec. 709).”
  • ? regarding “a real-time preset to match broadcast specifications (Rec. 709).”
    Posted by Keith Mann on June 19, 2015 at 4:27 am
    FCX 10.2 features” “a real-time preset to adjust the look of the image to match broadcast specifications (Rec. 709).”
    Does this mean:
    By “look” do they mean the program is in Rec 709 color space? Or is it still log and just adjusted to look like Rec 709?
    Is the FCX window simulating the look of what Rec 709 would look like on a broadcast monitor, so we do not “need” a second HDTV to color correct? Or are we still seeing log in the FCX window?
    Is rec 709 output from the thunderbolt / displayport so we can use a cheap displayport – to – HDMI adaptor to see rec 709 on a connected HDTV? Or do we still have to put a Rec 709 converter box downstream of the displayport?
    Does using the preset mean export is in Rec 709? All the time, for ProRes and mp4?
    Are there any downsides to using Rec 709 for web only distribution?
    Thanks in advance
    Jeremy Garchow replied 10 years, 10 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 19, 2015 at 2:46 pm
    If you shoot with a camera that encodes the color/gamma with a flat (or LOG) profile, X has built in selectable LUTs that transform the color and gamma to a 709 looking color space.
    If your camera doesn’t record with a log profile, normal HD video is 709 and normal editing will output a 709 compliant file.
