Activity Forums VEGAS Pro ? quality loss
  • ? quality loss
    Posted by Migel Rogers on May 19, 2006 at 7:13 pm
    I use vegas 4. After recording with Screencorder I brought the file into vegas to attempt to edit it, but the qaulity loss upon rendering was significant. Is there any recommendation for maintaining a reasonably good quality when rendering a file with vegas from a file that was generated from a recording of computer screen activity?
    Mig
    here’s a url for the samples, if you have time.
    https://www.migrogers.com/misc/test.htm
    Migel Rogers replied 20 years, 4 months ago 2 Members · 4 Replies
  • Gary Kleiner
    May 19, 2006 at 7:47 pm
    What is the resolution and scan type are you starting with? What are you rendering to?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Migel Rogers
    May 20, 2006 at 3:48 am
    Gary,
    I have to admit I’m a newbie with regards to these issues with video. The screencorder recording was taken at 20fps with a bit rate of 100 (the bit rate being a complete guess on my part, as some of my earlier guesses for bit rate, which were on the lower side, as low as 8, rendered nothing but black screen, whilst 100 worked fine).
    The vegas rendering, on the other hand, was the option of 512. I’m puzzled because even without any editing of the screencorder recording in vegas whatsoever, just a re-rendering in vegas at what I’d used with success in the past, created a file of essentially equal size – 1.39mb vs. 1.35mb – but with considerable quality loss. I do understand the concept of a files degrading with each pass of some sort of compression or manipulation, since I’m comfortable with photoshop; I just find this loss in quality in the video sphere rather significant, although maybe that’s just the nature of video, I don’t know. Or, I was thinking it had something to do with recording of a computer screen, something like you might see if someone took a camcorder and made a tape of a show on TV by pointing their camera at the actual TV.
    Mig
  • Gary Kleiner
    May 20, 2006 at 3:20 pm
    Your project or render settings are likely very different than the screen capture. For example, your capture may be 1200 x 1000 pixels, progressive scan. Your timeline is probably set to 720 x 480, interlaced. Those are going to look significantly different.
    Gary Kleiner
  • Migel Rogers
    May 20, 2006 at 11:55 pm
    Thanks Gary,
    that’s the type of information I need. I’ll look into that and see if I can get them to set up so as to marry, maybe that’ll work. I never thought of it like that.
    Mig.
