Activity Forums Adobe After Effects AE project cleanup
  • AE project cleanup
    Posted by Dave Teixeira on November 6, 2008 at 10:19 pm
    Right now I have a huge AE project with several older projects and many files that are not being used. I want to consolidate all my footage and elements so I can save a “finished” AE project with only the files/ elements I used in the project. Is there an easy way to do this?
    Also is there a way to quickly switch between camera angles? Like go from active camera to custom view 1?
    Mac Pro
    AE CS4
    Dave Teixeira replied 17 years, 10 months ago 2 Members · 2 Replies
  • Jan Sherlink
    November 7, 2008 at 12:05 am
    under the file menu you have; reduce project, consolidate …
    check the helpfile for what they exactly do.
    then, select your master-comps in AE and do a “collect files – selected comps”
    this will make a copy of your project with the needed files.
    temporarily rename your original project/assets folder so AE can’t link to the original files.
    now check your new project, doublecheck, triplecheck and quadriplecheck,
    after that, you can delete the original folder
    cya,
    EDIT:
    use F10, F11, F12 to switch between cameras,
    under the view-menu, you can change the shortcut/camera
    Jan
  • Dave Teixeira
    November 7, 2008 at 12:14 am
    Thanks Jan!
    Dave
