Activity Forums Zaxwerks AE problem with ProAnimator 6
  • AE problem with ProAnimator 6
    Posted by Christopher Key on January 14, 2014 at 8:04 pm
    Hi – I’m using pro-animator 6.1.1 and also subscribe to Adobe CC – my graphics card is NVIDIA QuadroFX-1500 – which does not support CUDA – so I know I am in need of a new expensive computer – unfortunately I am also in need of the $$$ to buy such, and in the meantime Pro Animator only works as a stand alone. My workaround will be to create animations and then render them as image sequ’s and import them into AE for extra work – I have 2 questions…
    1.Any ideas on how to get this to all work with my current config (win7 64 bit,Intel Quad core @2.4Ghz, 8 GB ram.)
    2.Any ideas on which computer system to purchase that will work well with Adobe, Sony Vegas, Cubase, Nuendo, C4D ….
    Thanks in advance for your suggestions and ideas. PS I want to upgrade to ProAnim 7, but it doesn’t make sense until this is resolved or I have new computer.
    Christopher Key
    Edward Wu replied 12 years, 8 months ago 2 Members · 1 Reply
  • Edward Wu
    January 15, 2014 at 10:28 pm
    Hi Chris,
    For your first question, ProAnimator Standalone should work without any problems on your current configuration. You can render the animation out as an image sequence or as a movie file and import the animation into After Effects or any other editing program you are using.
    As for your second question, I’m afraid I won’t be able to provide much feedback for that because I don’t have all of those programs. However, if you have a computer that has all of those programs running, then ProAnimator fly on that machine.
    P.S. If you’re interested in upgrading, you can still do so without a new machine since ProAnimator 7 will work on your current machine and can work as a standalone. You can still have the same workflow of rendering out your animation and importing the animation into After Effects or any other editing program. For $30 more, you can have both the Standalone Application as well as the After Effects Plug-in.
    Hope this helps and good luck with your search for your new machine!
    Best,
    Edward
