Activity › Forums › Adobe After Effects › AE-Premiere dynamic link not working unless both versions are CC2015.3?
Posted by Michael Trenton on July 28, 2016 at 5:00 pmHi there,
After running CC2014 of After Effects, Premiere, Audition, Media Encoder and Speedgrade for about a year I upgraded everything except After Effects to CC2015 a few months back.
A couple of weeks ago I needed to have dynamic link between Premiere and AE to do some effects work so I decided to also upgrade After Effects (Adobe CC automatically updating AE to CC2015.3 and also updating Media Encoder), but the ‘REPLACE WITH AFTER EFFECTS COMPOSITION’ dialogue is still greyed out.
So does this mean I will have to also upgrade Premiere from CC2015 to CC2015.3 in order to make this option available to me again?Roei Tzoref replied 9 years, 11 months ago 4 Members · 11 Replies -
Walter Soyka
July 28, 2016 at 5:06 pmYes, Dynamic Link only works between applications with the same version.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Walter Soyka
July 28, 2016 at 5:15 pm[Dave LaRonde] “You could do your AE voodoo in CC 2015 (although if you don’t HAVE to, I wouldn’t)… Or as hinted at above, just work in AE CC 2014.”
Are you running 2015.x at your stations now?
I did some work on Ae CC 2014 last week — I was using it to render (multiprocessing!) and decided to make some adjustments right on the spot — and I was really stunned at how pokey it was compared with Ae CC 2015.3. There are real, noticeable improvements in 2015. I feel that in our workflow, going back to CC 2014 for day-to-day work would be a major step backwards. Ae CC 2015 certainly has its share of issues, but for us, it’s worth the tradeoff.
Walter Soyka
Michael Trenton
July 28, 2016 at 5:24 pmThanks for your replies. It surprised me at first because I had hoped dynamic link would work as long as the software were all the same ‘big’ version (CC2014, CC2015 etc) and not that I’d lose dynamic link over differences in incremental versions numbers. That’s a bit annoying I guess (particularly since I’ve heard rumours that ‘direct link to Speedgrade’ has been removed in Premiere CC2015.3).
Dynamic link to Media Encoder still works both from Premiere CC2015 and AE CC2015.3 though so could it really be so hard for Adobe to keep dynamic link working between incremental versions?I’ll guess I might as well upgrade all the rest of my Adobe software like Audition to CC2015.3 as well then. I reckon there is no hope that Adobe will release a Speedgrade CC2015.3 so I might as well start using DaVinci Resolve for colour grading instead.
Walter Soyka
July 28, 2016 at 5:26 pm[Michael Trenton] “I’ll guess I might as well upgrade all the rest of my Adobe software like Audition to CC2015.3 as well then. I reckon there is no hope that Adobe will release a Speedgrade CC2015.3 so I might as well start using DaVinci Resolve for colour grading instead.”
Ae CC 2015.3 is a separate install. You can still have Ae CC 2015 installed side-by-side if you wish.
Adobe has made some big changes to color in Premiere with the updated Lumetri Color Panel. You can do a lot of color directly in editorial now, but you’re right on that it’s no SpeedGrade or Resolve.
Walter Soyka
Michael Trenton
July 28, 2016 at 5:39 pm[Walter Soyka] “Ae CC 2015.3 is a separate install. You can still have Ae CC 2015 installed side-by-side if you wish.
Adobe has made some big changes to color in Premiere with the updated Lumetri Color Panel. You can do a lot of color directly in editorial now, but you’re right on that it’s no SpeedGrade or Resolve.”
Thanks. I already have AE CC2015.3 installed so it’s Premiere that I’ll need to upgrade from CC2015 to CC2015.3 in order to make dynamic link work between them.
But I guess I could keep Premiere CC2015 installed so that I still have a version of Premiere with direct link to Speedgrade? It’s not gonna potentially mess anything up having multiple versions of Premiere installed is right?Yes, I’ve heard the Lumetri panel have had some upgrades so I’m excited to test that out when I upgrade to 2015.3. I was really hoping Adobe would absorb all of Speedgrade’s functionality and level of control into Premiere before they decided to ditch Speedgrade though. That’s a huge dissappointment on Adobe’s part in my book.
Walter Soyka
July 28, 2016 at 5:43 pm[Michael Trenton] “Thanks. I already have AE CC2015.3 installed so it’s Premiere that I’ll need to upgrade from CC2015 to CC2015.3 in order to make dynamic link work between them.”
I think that if you kept Premiere CC 2015 and re-installed Ae CC 2015, you could use it to handle the setup and rendering for your dynamic link projects (even if you ultimately choose to do most of the work in Ae CC 2015.3).
[Michael Trenton] “It’s not gonna potentially mess anything up having multiple versions of Premiere installed is right?”
I have every major release of Ae/Pr installed on my workstation going back to CS6. It all works fine.
[Michael Trenton] “Yes, I’ve heard the Lumetri panel have had some upgrades so I’m excited to test that out when I upgrade to 2015.3. I was really hoping Adobe would absorb all of Speedgrade’s functionality and level of control into Premiere before they decided to ditch Speedgrade though. That’s a huge dissappointment on Adobe’s part in my book.”
I hear you.
Walter Soyka
Michael Trenton
July 28, 2016 at 6:41 pm[Walter Soyka] “I think that if you kept Premiere CC 2015 and re-installed Ae CC 2015, you could use it to handle the setup and rendering for your dynamic link projects (even if you ultimately choose to do most of the work in Ae CC 2015.3).”
Yes I guess that’s certainly an option. I may consider this although now I’m a bit curious to check out version 2015.3 of Premiere. Though I’m not really sure how to install older versions of Premiere anyway now that the Creative Cloud application have automated the upgrading process. Is there even an option in the Creative Cloud app to install older versions of the applications?
[Dave LaRonde] “Just a reminder — don’t let the new install delete your existing suites of applications! You have to tell the installer, “No, I don’t want to uninstall the old ones.””
Thanks. I’ll be sure not to delete my previously installed programs.
Walter Soyka
July 28, 2016 at 6:49 pm[Michael Trenton] “Is there even an option in the Creative Cloud app to install older versions of the applications?”
Yup:
https://helpx.adobe.com/creative-cloud/help/download-install-app.html#topic-3
Walter Soyka
Michael Trenton
July 28, 2016 at 7:13 pm[Walter Soyka] “Yup:
https://helpx.adobe.com/creative-cloud/help/download-install-app.html#topic...”
That’s awesome! Thanks a lot!
Tim Chan
October 14, 2016 at 12:39 amHey,
I started to have this issue with dynamic link not working after I upgraded Premiere Pro and Adobe After Effects a few days ago. Before it worked totally fine.
After browsing the internet for hours it seems like some were right with this suggestion:
You have to have the exact same version for Premiere Pro and After Effects in order to use dynamic link. I just used Creative Cloud and downloaded CC 15.3 FOR BOTH programs and now it works so smooth.
