Activity › Forums › Adobe Premiere Pro › AE plugins in premiere CS5?
  • AE plugins in premiere CS5?
    Posted by Matthew Woods on July 20, 2010 at 4:39 pm
    Hi all,
    I wanted to know if its still possible to use some AE plugins in premiere CS5. If so, how do I do this. I can’t seem to find premiere’s plugin folder.
    I would like to add AE’s “Iris wipe” plugin to premiere because of its feathered edge feature. I noticed AE’s feathered linear wipe and radial wipe plugs are already there under video effects “transitions”
    -Matt
    Angelo Lorenzo replied 16 years, 1 month ago 2 Members · 1 Reply
  • Angelo Lorenzo
    August 3, 2010 at 4:28 am
    Try sticking the plug-in into C:\program files\Adobe\Common\Plug-ins\CS5\MediaCore to share the plugin in both programs, or make a copy of the AE plug into Premiere’s plug-in folder.
    No guarantees it’ll work, they share the same plugin architecture but faulty ones will probably crash premiere immediately upon the use of the effect.
    Good luck!
