Activity › Forums › Adobe After Effects › AE Not Looping RAM Preview
  • AE Not Looping RAM Preview
    Posted by Mark Walczak on November 5, 2009 at 2:58 pm
    Hi gang,
    So, this one is a real head-scratcher! When I start AE, my preview panel defaults to having my RAM previews loop when playing, which is exactly what I want. The problems is this: When I create and attempt to playback RAM previews, it will play once, then stop and clear the last 10% of frames from memory. In order to get it to loop properly, I need to cycle through all of the playback options (oscillate, play once, loop) until I finally get it to loop. Once I select loop (even though it was selected at startup), it works properly. I am running CS4 on a Mac Pro. In speaking with a colleague, he used to have the problem on CS3. No one else in my company is having this issue.
    Any and all insights would be greatly appreciated, as this is REALLY annoying.
    Mark Walczak replied 16 years, 10 months ago 30,975 Members · 2 Replies
  • Mark Walczak
    November 5, 2009 at 7:48 pm
    Hm, I wouldn’t think so, as my system has 10GB.
    Thanks for replying, Dave! 🙂
    What makes you explode?
    http://www.explosivegraffix.com
  • Mark Walczak
    November 11, 2009 at 2:42 pm
    Hi Dave,
    I suppose the only problem may be related to multiprocessing, however, I am using the standard settings. Again, I doubt that other programs would hurt me, as I only tend to have Firefox open simultaneously.
    Anyone else have any insights?
