Activity › Forums › Adobe After Effects › AE not finding Alpha Channel
  • Nikos Mamalos
    June 16, 2010 at 12:19 pm
    Just in case you haven’t thought it. In the project window R-Click the png. and check if the interpretation of the file alpha channel is checked
  • Michael Szalapski
    June 16, 2010 at 1:13 pm
    Also, there’s no reason at all to export as anything from Photoshop. AE works beautifully with Photoshop files.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Gully Moore
    June 16, 2010 at 5:10 pm
    The interpretation says, “Straight – Unmatted”
    When I try to change it it “Ignore” or “Premultipied – Matted with Colour” and press OK, it dosen’t seem to stick, so when I go back to it it’s still on “Straight – Unmatted”
    I don’t really know what any of that means, but it seems very strange that finder recognises an alpha channel and not AE. I have 4 similar images that I have done the same thing with, 2 work fine, and the other 2 are like this.
    Is there any other way to get rid of the white? After that I want to Track Matte the image to a video (so the video is in the shape of the silhouette).
    Thanks for the help 🙂
  • Nikos Mamalos
    June 17, 2010 at 2:58 pm
    I cannot explain it. Straight unmated should work correctly. I repeated your steps just to check. Now R-click reload the footage. If it does not work I will agree with Michael Szalapski. PSD would have done it at first place. Good luck
