Activity Forums Adobe After Effects AE mask goofiness… won’t show result in comp
  • AE mask goofiness… won’t show result in comp
    Posted by Tim Bird on July 5, 2010 at 8:04 pm
    For the last couple of weeks, AE has not been showing the result of a mask in the comp window, nor will it preview render the mask. If I open a layer in the layer preview window it displays the result with the mask… just not in the comp window.
    The layer preview window has an check box for “Render” which toggles the mask preview on or off but there is no such toggle for the comp window (that I can find anyway.)
    HELP is greatly appreciated.
    Tim
    Tim Bird
    tim@Blast-Edit.com
    Blast Editorial Services, LLC
    Richardson, TX 75081
    MacPro 2.66, FCStudio 3, Adobe Production CS3
    Tim Bird replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
