Activity › Forums › Adobe After Effects › AE Layer Timeline Gradient
  • AE Layer Timeline Gradient
    Posted by Thomas Brecheisen on December 10, 2015 at 6:47 am
    This has been hard to Google, since there are millions of results for “Gradient Tool,” but a student sent me a screenshot of his timeline and one of his layers has a gradient in the timeline. If this is something common on old, I’ve never come across it. Is it common or new?
    I recognize the screenshot lacks information in the layers, but I believe this either an Adjustment Layer or Solid with an effect keyframed on it. I asked for a more detailed screenshot, but did not receive one yet. I thought I’d ask in case this IS enough information. If not, please let me know what I need to capture to get an answer. Thanks guys!
    https://www.dropbox.com/s/84st8ofup1myjqs/Screen%20Shot%202015-12-09%20at%203.27.46%20PM.png?dl=0
    Thomas Brecheisen replied 10 years, 9 months ago 2 Members · 4 Replies
  • Walter Soyka
    December 10, 2015 at 2:22 pm
    That shows a color property which has been keyframed from yellow to black.
    Any color control will do this; a light’s color, a shape’s fill/stroke color, a color control on an effect like Fill, etc. Once a color property has been keyframed, you can twirl it open and see this color band (or press the U key to reveal keyframes) and how it changes over time.
    It has been around for quite some time, but if you never keyframe colors, you’ll never see it.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Thomas Brecheisen
    December 10, 2015 at 3:33 pm
    Thanks Walter. I’ve been using and teaching AE for years and NEVER seen that before. I guess this leads to my next question…. how do you keyframe the color? I don’t see a keyframe option when I select the label color. Thanks!
  • Walter Soyka
    December 10, 2015 at 4:33 pm
    It’s not a label color.
    Add the Fill effect to a layer. Click the stopwatch next to the Color control. Move the timeline forward and change the color. Press U in the timeline with the layer selected to reveal its changed keyframes. You’ll see the Color control shows the color at the current time via that gradient.
    Walter Soyka
  • Thomas Brecheisen
    December 12, 2015 at 6:23 am
    Ah, it’s an effect on the layer, not the actual layer itself, got it. The screengrab I was given looks like it was it’s own layer at first glance.
    Well, that’s awesome. I never knew that happened. Do any other effects give you visual information like that within the timeline? I think I’ll have to investigate. Thanks.
    Solved: Walter Dec 10
