Activity Forums Adobe After Effects AE – Illustrator colour problems.
  • AE – Illustrator colour problems.
    Posted by Frank Weber on September 17, 2009 at 4:15 pm
    After Effects (CS4) still doesn’t import layers correctly from Illustrator; Colours are messed up and the transfer modes don’t stick:
    They lose their opacity information and default to “normal mode” instead of “multiply” or “screen”, etc.
    Please help. It’s killing me.
    Michael Kelley replied 10 years, 5 months ago 3 Members · 4 Replies
  • Frank Weber
    September 18, 2009 at 7:40 am
    OK… Well, anyway, for everyone else out there:
    – There is no answer to the “transfer modes” question. So work around it.
    – Change your colour interpretation settings in Project Settings to ADOBE 1998 (so that AE interprets imported colour profiles), then change the Colour Management in the (Import)Interpretation for each layer to “Preserve RGB”.
    That fixes the colour problems.
  • Frank Weber
    September 21, 2009 at 12:40 pm
    Correction:
    It still renders out wrong.
  • Vitaly Tomachevski
    December 21, 2013 at 10:13 am
    I was having a similar issue. My colors were not matching from Illustrator to After Effects while using ai files. Until I tried this.
    In Illustrator,
    First turn all of you Spot colors to Process colors.
    Next, Go to File – Document Color Mode and select RGB Color.
    Then, Go to Edit – Assign Profile and select a profile.
    (For example: sRGB IEC61966-21)
    Make sure that in After Effects you set the same color profile as in Illustrator by going to File – Project Settings – and selecting a working space profile
    When you are about to render and select add to render que, Go to Output Module – Color Management tab and select an output profile you wish to convert the colors to such as sRGB IEC61966-21.
    Hope this helps.
  • Michael Kelley
    March 24, 2016 at 9:59 pm
    Awesome! works like a charm. This post saved my butt.
