Activity › Forums › Adobe After Effects › AE: how to shoot and edit these videos?
  • AE: how to shoot and edit these videos?
    Posted by James Mayo on December 10, 2008 at 3:56 pm
    How to shoot and edit these following videos?
    How to make film burn and/or film reel effect?
    and how to shoot/make those vanishing people and things on this wedding video?
    Thanks a Lot!
    Mark Suszko replied 17 years, 9 months ago 2 Members · 3 Replies
  • Mark Suszko
    December 11, 2008 at 3:43 pm
    The vanishing thing is an old trick: dissolving between two matched copies of the same shot, one with the person, one without. The added touch here is the shots have motion, which complicates the job. You can get that by using a robotic motion control rig, or if you shoot in HD and post/output to SD, you have enough room in the HD frame to move it around in post with keyframing to make the two shots match. Or you can painstakingly roto the guy out, but that’s too much work. Another possibility is to shoot a 10 megapixel still of the empty room and use that as the plate, tracking anc compositing as previously described.
    I liked that cover of the Beatle’s song, who sings it?
  • James Mayo
    December 12, 2008 at 9:06 am
    Oh I thought it was an easy shoot…Lolz! Is there an easy way to shoot that kind of effect? i mean the fading out of people in camera in motion?
    about the song..i don’t know who’s the artists but i think it’s from the Philippines. But I’m not sure.
  • Mark Suszko
    December 12, 2008 at 10:35 pm
    The dissolve to empty room effect IS easy, childishly so, if you lock down the shot and don’t move the camera in any way. Build that effect in a wider than normal frame, then pull that frame in with keyframing tools and you can, within limits, impose the pans and zooms after the fact.
